  • 655 Answers
In batch programming you can use your DOS command internal/extarnal or any program you can run.
You have to just write your commands in the sequence in which you want to run them, in a text format, and save them with a extension of .BAT. Thats all you have to do in a batch file program.
Click on this link to see some examples from Micro Soft:
Please don't forget to rate this........ :)
Posted on Mar 29, 2008
Give me a idea for braking a password for usear accounts
Posted on Apr 11, 2008
  • tushu Apr 11, 2008
    i forget my administrator password and my all user account are disable by me expet one give me a soluson for it your dear tushar.
How to Create a Batch File?
Use "notepad" to type in the commands you want in the batch. Save the file with the extension, "cmd" as in, "batch.cmd". You have a batch file now. It's just commands in a file.
Oct 18, 2016 | Computers & Internet
What happens wen rtc Batt is unloaded
Hello. batt files or batch files are used by your operating system to run a list of commands created by ms-dos or by you. A good example of a batch file is the autoexec.bat which is loaded each time the computer boots to MS-DOS. Batch files are like shortcuts on your desktop, when they are run they pass information through the command line and these sets of instructions run commands or programs on your computer. Did that help?
Feb 09, 2014 | Acer Predator G3620-UR308 - Core i7 3770...
Can anyone explain how batch file works?
This is kind of tricky not knowing how familiar you are with the commandline, but a batch file simply contains single commands and executes them in order (usually from top to bottom). A batch file (or bash script in Linux) can be very helpful if you have to run certain commands over and over again, so you don't have to write them by hand.
An Example: You want to store your network settings in a text file.
You open the command prompt (WIN+R) and type this line:
mkdir C:\Network
Then you type this line:
ipconfig /all > C:\Network\ipconfig.txt
The first line creates a folder on your C: drive called "Network"
The second line runs the ipconfig command and saves it as a text file in that new folder.
To make a batch file, you open Notepad and insert the two lines. Then save it as "IP.bat" (make sure not to save it as "IP.bat.txt"! This is the most common mistake. If you save a file from Notepad, select "All Files" in the "Save As Type" dialog. Otherwise it will save it as a .txt file and you have to rename it later.)
Now you can double click the batch file and it runs all commands in the file.
You can also see the danger. If you run a batch file and don't know what it really does, it can destroy your whole system. So make sure you understand it and/or get it from a trustworthy source.
A nice example of how complex a batch file can be is here:
Copy the content into a text file, save it as AllHelp.bat, run it and it will create a webpage with all available DOS commands.
Hope this helps - otherwise let me know if you have specific questions.
Feb 26, 2012 | HEWLETT-PACKARD Computers & Internet
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
What is best website to show me dos programming examples.. want to creat an exe file to pick up text files from a directory and send them to a printer whenever a new file appears .(without pc...
you mean a .bat file that can be run when a new file is added. let me see if i can find a good site for you.
My advice is get a good book! One that stands out in my mind is "The Waite Group's MS-DOS Bible" (1991?) This will take you through using the command shell and batch files through how the DOS filesystem is structured, memory managment under DOS, an explaination of how the OS loads a program up to wrting little progams of you own using machine language and debug.
Another great book is Dan Gookin's "Advanced MS-DOS Batch File Programming" that will also teach you something about operating systems in general in a nice, unformal tone.
DOS also comes with a BASIC interpreter called QBASIC, that can teach you the funamentals of programming while augmenting your shell scripts and doing things that plain batch files just can't do.
Aug 03, 2010 | Microsoft Windows XP Professional
Copying to c:\ in vista using batch files..
You need to left click the batch file and "Run as Administrator".
Nov 01, 2009 | Microsoft Windows Vista Ultimate Edition
How to use cmd ?
to use the command prompt, press the "start" and "R" keys on the keyboard.
On the small, "Run" screen, type cmd.
click ok.
type help in the command prompt. This should print a list of commands that you can use with it.
This is what it puts on-screen:
For more information on a specific command, type HELP command-name
ASSOC Displays or modifies file extension associations.
AT Schedules commands and programs to run on a computer.
ATTRIB Displays or changes file attributes.
BREAK Sets or clears extended CTRL+C checking.
CACLS Displays or modifies access control lists (ACLs) of files.
CALL Calls one batch program from another.
CD Displays the name of or changes the current directory.
CHCP Displays or sets the active code page number.
CHDIR Displays the name of or changes the current directory.
CHKDSK Checks a disk and displays a status report.
CHKNTFS Displays or modifies the checking of disk at boot time.
CLS Clears the screen.
CMD Starts a new instance of the Windows command interpreter.
COLOR Sets the default console foreground and background colors.
COMP Compares the contents of two files or sets of files.
COMPACT Displays or alters the compression of files on NTFS partitions.
CONVERT Converts FAT volumes to NTFS. You cannot convert the
current drive.
COPY Copies one or more files to another location.
DATE Displays or sets the date.
DEL Deletes one or more files.
DIR Displays a list of files and subdirectories in a directory.
DISKCOMP Compares the contents of two floppy disks.
DISKCOPY Copies the contents of one floppy disk to another.
DOSKEY Edits command lines, recalls Windows commands, and creates macros.
ECHO Displays messages, or turns command echoing on or off.
ENDLOCAL Ends localization of environment changes in a batch file.
ERASE Deletes one or more files.
EXIT Quits the CMD.EXE program (command interpreter).
FC Compares two files or sets of files, and displays the differences
between them.
FIND Searches for a text string in a file or files.
FINDSTR Searches for strings in files.
FOR Runs a specified command for each file in a set of files.
FORMAT Formats a disk for use with Windows.
FTYPE Displays or modifies file types used in file extension associations.
GOTO Directs the Windows command interpreter to a labeled line in a
batch program.
GRAFTABL Enables Windows to display an extended character set in graphics
HELP Provides Help information for Windows commands.
IF Performs conditional processing in batch programs.
LABEL Creates, changes, or deletes the volume label of a disk.
MD Creates a directory.
MKDIR Creates a directory.
MODE Configures a system device.
MORE Displays output one screen at a time.
MOVE Moves one or more files from one directory to another directory.
PATH Displays or sets a search path for executable files.
PAUSE Suspends processing of a batch file and displays a message.
POPD Restores the previous value of the current directory saved by PUSHD.
PRINT Prints a text file.
PROMPT Changes the Windows command prompt.
PUSHD Saves the current directory then changes it.
RD Removes a directory.
RECOVER Recovers readable information from a bad or defective disk.
REM Records comments (remarks) in batch files or CONFIG.SYS.
REN Renames a file or files.
RENAME Renames a file or files.
REPLACE Replaces files.
RMDIR Removes a directory.
SET Displays, sets, or removes Windows environment variables.
SETLOCAL Begins localization of environment changes in a batch file.
SHIFT Shifts the position of replaceable parameters in batch files.
SORT Sorts input.
START Starts a separate window to run a specified program or command.
SUBST Associates a path with a drive letter.
TIME Displays or sets the system time.
TITLE Sets the window title for a CMD.EXE session.
TREE Graphically displays the directory structure of a drive or path.
TYPE Displays the contents of a text file.
VER Displays the Windows version.
VERIFY Tells Windows whether to verify that your files are written
correctly to a disk.
VOL Displays a disk volume label and serial number.
XCOPY Copies files and directory trees.
this window is used only when the desktop cannot be accessed.
For a user-friendly interface (easier to use), use My computer to do common tasks.
Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
