Question about Panasonic PT-44LCX65 Television
How do i know if the ballast needs to be replaced? i recently replaced the lamp and the TV worked with the new lamp for several weeks, then one day when i turned it on, the red power light started flashing, then the "lamp" indicator light started flashing every few seconds
  • jagermeis521 May 13, 2010
    The description on the packing slip is Panasonic TY-LA1000, however there is also a Phillips sticker on the box.
    The description on the packing slip was Panasonic TY-LA1000, however there was also a Philips sticker on the box. It was purchased from discount-merchant.com...
  • 87 Answers
Did you buy and OEM Panasonic lamp in a Panasonic box?
Posted on May 12, 2010
  • George Kopp May 13, 2010
    See if a local repair shop that is a Panasonic Authorized Servcie Center has a TEST lamp that they know is good and will let you try. The place you purchased from did not sell you an OEM lamp
TV blue light comes on, then the red light blinks two times, on the 3rd blink, it goes into rapid blinking. I replaced the lamp and it worked for a week, but then the same issue. I put the old lamp back...
some units require a lamp counter reset.the ballast usually starts at extreme output and at certain hour interval the ballast would start to decrease voltage as the bulb ages.to reset on some models can be reset using the remote
Aug 12, 2013 | JVC HD-61Z786 61" Rear Projection HDTV
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have a mitsubishi tv that cuts off after about 30 seconds and lamp light is red but i replaced lamp 1 week ago.
Hi
Well if you have replace the lamp just recently what could be happening here is that your ballast is not working properly and is to week to keep you lamp running,The definition of the ballast:
How It Works
The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp.
The lamp works with the ballast to project light into a light engine that separates the colors of the light, then recombines them with an image.
The image is then reflected on the back of the TV and then onto the screen.
If the ballast is to weak it will no have enough power to send the 15,000 volts to get the lamp ignited
You can get more check this websites http://www.partstore.com/Part/Samsung/Samsung/BP4700029A.aspx?s=froogle or http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi+Ballast?click=52978
Please keep us posted
Samuel
Nov 16, 2009 | Televison & Video
Mitsubushi tv model # 52327 ballast replacement
The ballast for the lamp too should be replaced along with the lamp. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Mitsubishi WD-62525 62" Rear Projection...
KDF-E42A12U - Three Standby flashes???
There is the possibility that you might have a defective ballast, it might not have enough voltage to keep up with your new lamp, and that's why it switches off and makes the 3 indicator lights flash, letting you know that the bulb is defective, but it's not the bulb, it's the ballast
Jul 13, 2009 | Sony Televison & Video
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
LED green and red light blink
the ballast should make momentary arcing sound and orange flash in its spark gap tube when it 1st trys to light the lamp. look for it in the darkness it will be easier to spot, as you listen for it. make sure you are buying toshiba factory replacement lamp.
Jan 14, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Sound but no picture
there are several things that need to take place for the lamp to turn on. first the color wheel needs to turn on ( if you can hear a whinning noise then this is fine) next the tv will send a signal to the lamp ballast to turn on, and the ballast needs the 130v dc supply from the power board ( simoly remove the lamp and reinstall the lamp door, turn tv on, and if you hear an arcing noise from the ballast you know this is fine too. the board that controls all of this is the dmd board. so if the color wheel works, ballast starts then i would replace the dmd board....
Oct 24, 2007 | Samsung HLP5085W 50" Rear Projection...
Panasonic PT-44LCX65 Television Logo
420 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
