Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
Power went out and now my router is working fine but the wireless PCs cannot connect. "Limited or no connectivity" even though signal strength is excellent. Tried cycling the router. no luck.
    Master:
  • 441 Answers
Access the router's setup page/configuration page and change the channel of your wirelessrouter to 1, 3 or 11. Make sure you know if the wireless encryption is ON and get the key.
Posted on May 13, 2010
How can I troubleshoot My router? It is turning on and off all time.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Mar 16, 2013 | Computers & Internet
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
My d-link dir 615 wireless router will work fine and then just lose the signal and i have to un-plug the router and then re-plug it in again before it will work again why is this
Oct 16, 2012 | D-Link DIR-615 Wireless Router
My wifi doesn't work.
Oct 08, 2012 | Computers & Internet
Hi I have a RangeMax - and it has always been working fine. Last week I couldn't connect wirelessly, so I reset. Nothing. Now I've tried connecting wired through the hub - still nothing. The power is...
Can you please check the signal strength of the wireless router.
If you can log into the wireless router management page and check for the erros if any inside the logs.
Oct 30, 2010 | NetGear RangeMax WPN824 Router
LIMITED OR NO CONNECTIVITY WITH AN EXCELLENT SIGNAL STRENGTH WITH TWO NOTEBOOKS
Wireless connection ...limited connectivity
If you connect the computer to the router , does it works? If the wired is on line that means the wired connection is OK.
Open the set up page of the router check the
wireless settings of the router.
I think your network is secured and you are not
typing the correct network key.
just open the router set up page and check the wireless settings.
Click Here for step by step solution
Feb 28, 2010 | B&G Computers & Internet
ADAPTER not working
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Feb 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Aug 20, 2009 | Samsung NC10-14GW Notebook
Router stopped braodcasting the wireless signal WRT160N
maybe your router got fried somehow. it's a pretty common thing if you didn't disconnect the power scorce first.
Aug 12, 2009 | Linksys WRT160N Wireless Router
Limited or No Connectivity
Yes, the wireless adapter can be fixed, by replacing the motherboard.
Jun 09, 2007 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
113 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
