Question about Garmin eTrex GPS Receiver
Loading gps marks e Trex hand held yellow
Hi there had the gps unit for a few years could not use so i left it in the draw now i have a boat and am trying to input coordinates that i have to go to fishing spots have know idea how to put them in . ( OLD SCHOOL )
Cheers Andrew
  • 35 Answers
I would guess you no longer have the manual or you would not be asking.
Use PAGE button to go to MENU
Select MARK (the first one) by pushing ENTER
Push UP to change name for waypoint
Enter to select first letter, up / down to choose letter, ENTER
When complete DOWN , DOWN DOWN to change Coordinates
Change each coordinate number the same as letters above
When done use UP to select OK
ENTER
Your newly named location will be under WAYPOINTS on the MENU, Use UP/DOWN to locate then ENTER to select
Then GOTO
Of course you must have this in the correct format (several are available, usually UTM or WGS84 MM:DD:SSS found under settings) and have a location coordinate to enter
Posted on Apr 01, 2008
  • Garmin Master
  • 638 Answers
Your manual tells you how to enter waypoints
http://www.fixya.com/support/p237226-garmin_etrex_gps_receiver/manual-14514/page-16
  • TO Lady Apr 01, 2008
    The link seems to have run off the page. Download the online etrex manual, and go to the page "Entering Waypoints".
    It's always best to read the manual completely if you are dealing with new technology.
My Garmin GPS 12 XL will not power up. Is that an internal battery problem or is the unit shot as Garmin technicians tell me?
try swapping out the batteries, no harm in opening it up with a screw driver (will void the "warranty" that expired 12 years ago) check if there is an internal battery (usually a coin cell battery like cr 2025 or CR2020) otherwise it is dead and time to get an e-trex 30... great simple little unit with lots more features
Jul 09, 2014 | Garmin GPS 12XL GPS Receiver
What is procedure to delete courses from the hand held devise? i have the SG4 Model. Thanks
Hello.
GPS receiver units are designed to translate signalsreceived from a satellite into recognizable graphic information using mappingsoftware. These systems are dependent on the installed software, butlike all computers they can experience problems up to and including unexpecteddeletion of the software. Because of this, many GPS systems have providedsolutions to some of the most common problems.
Operating System Deletion
If the hand-held unit does not display any functionality when activated,first try restarting the system. If the unit is a hand-held GPS, try removingand then re-inserting the batteries to reset the system. If the system still displaysno operating system, contact a professional for service. GPS software can alsobe bundled or purchased as part of a more comprehensive device, such as aniPhone or other smart phone. In this instance, it is possible that the softwarewas deleted from the system during a sync with a computer. Try re-syncing thedevice with the computer and ensuring that the GPS application has beenselected to be loaded onto the unit. If this does not solve the problem, thesoftware may be corrupt. Delete the program from the computer and download itonce again to the hard drive. Then, re-sync the newly downloaded application toyour device.Update Deletion
Occasionally, an error in the download or an error insyncing with a GPS hand-held can cause updates such as operating systemadvances, bug fixes and new map information to be deleted or corrupted. If thisshould happen, re-download the update information and sync it with the GPSunit. If update information comes in the form of an SD or other data card, thecard itself may be corrupted. Contact Thanks.
Sep 21, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Display on my Garmin E-Trex Legend GPS
Sounds like the screen is shot and theres nothing really you can do to fix it, sorry :(
You can send it to Garmin for the flat rate repair fee of $79 dollars. I would recommend getting the new eTrex Legend H with the high sensitivity receiver if you want a similar model. It's sat reception will blow the prior version out of the water and has 24mb of memory rather than the 8mb it used to have.
Jan 19, 2009 | Garmin eTrex Legend GPS Receiver
No reply from garmin
We are NOT garmin, we are a help site for various products. You'd be best to write Garmin with all the details of your unit ID, date sent, etc.
Jan 12, 2009 | Garmin eTrex Legend GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Yes, this problem has been caused by the launch of a new satellite earlier this year. As soon as your unit gets a fix from the new satellite, it causes this problem. Simple immediate fix: disable WAAS in the setup. Permanent fix: go to Garmin website and update your unit's software and it will fix this temporary problem. Enjoy your GPS and don't forget to come back and tell us if this fixed your problem.
Aug 19, 2008 | Garmin 010-00358-00 GPS Receiver
310 c garmin gps on boat not working
Hi, 673king, My Garmin is c330, but I think that all GPS's of this nature are programmed only for roads -- not bodies of water. I haven't updated my 2-yr.-old-Garmin yet for new maps, but what you describe concerning the red question mark is exactly what I get when I am on a road that was constructed after my Garmin was programmed. Since the GPS can't find the road in its memory, it merely has a red question mark until I get onto a road that the software recognizes. It then operates as usual.
Aug 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Internal chip
C-Map (chart) cartridges
Aug 08, 2008 | Raymarine Raynav 300 GPS Receiver
I've got a garmin E-Trex Vista CX and Mapsource software. After creating routes & waypoints (for Ben Nevis, Scafell Pike & Mount Snowdon) when I download these to the GPS unit each subsequent...
The contours are not coming from the routes and waypoints, they are coming from the mapping software. You must load all the map segments at once to your unit. You can upload routes and waypoints separately and they will not erase the other ones already on the GPSr unit.
Apr 21, 2008 | GPS
Tomtom 910.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
Garmin eTrex GPS Receiver Logo
231 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
