Question about Kenmore 44072 Front Load Washer
Changing belt hi i need to put a new belt on an hotpoint aquarius 1100 wm63 machine . the belt appears to short even when ive loosened the motor right off can you help me please
The belt seems to be too short, how can i get the belt on the motor and the pulley on the drum?
Posted on Sep 17, 2008
How do I refit the belt on my hotpoint aquarius wma46s
(providing yours is front loading?)
The quick answer is 'DON'T'! Purchase a replacement and fit that 'cos the old one will only come off again!
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT AGAINST THE MOTOR OR FRAME; THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 20, 2011 | Hotpoint WMA46 Front Load Washer
Washing machine doesn't want to spin. The belt is not in place.
You need to purchase a replacement belt; if you replace the old one it will only come off again.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
John C
Aug 20, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquirius 1100 - WM63 Hi, A leak has sprung from my washing machine and being fairly capable I've already had the sump off cleaned that out and re- attached it and checked the door seal for...
Hotpoint Aquirius 1100 - WM63 leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 31, 2011 | Hotpoint Aquarius WD63 Front Load...
The belt keeps on coming off i keep putting it back on but about 6/8 washes after it comes off whats wrong?
I suggest 1) a replacement belt and 2) follow my guidance notes on fitting ;-0)
These are pre-typed!
Hope this is your problem solved.
Good luck,
John C
Mar 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
The belts come off, its a hotpoint aquarius wm63.
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
How to cahnge carbon brushes
The brushes usually "come complete with brush-holders", which is a way of selling you something extra that you don't need. Easiest way is to disconnect the machine from the power and the water, turn it onto its front on an old cardboard box and remove the motor from its mountings on the washer. You can usually get acces to one of the brushes really easily and the other is guaranteed to be a real pig, so keep it simple. The brush-holders are usually fastened to the motor casing with either self-tapping screws or small bolts.
I buy my brushes from Ebay sellers and always send them a digital photo of the old brush together with the make and serial number off the motor itself, just to be sure. Brushes can look similar and be that silly millimetre too short, or long, or wide.
Did that answer the question? If not, add a comment and I'll expand further as necessary. Cheers, D.
Jul 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 WM63
some times when there is no motor action people think the machine has stuck try a set of brushes you must diconnect from the electrical mains first if unsure call an expert you can not put a price on safety
Oct 08, 2006 | Hotpoint Aquarius WD63 Front Load...
Kenmore 44072 Front Load Washer Logo
148 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
