Question about Estate TEDX640JQ Electric Dryer
Not enough heat
Chnged out the theromostats, and heating element and still not producing enough heat, only three coils heat up.
  • 109 Answers
First check for proper voltage, second check for open limits, third check airflow,( make sure there is plenty), if not enough airflow the limits will turn off elements.
Posted on Mar 30, 2008
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
Unit is GQ3RA-036K with H3HK010H-01B heat strip. I have checked continuity on the coils and the temperature switch both check fine. I have measure the voltage on the red and black wires connected to the...
you need to ohm out the heater elements. Its the ohm reading that will give you insight as to whether or not the coils are bad.
When ohming out the elements, be sure to tag and disconnect all electrical leads to the meter...otherwise you will get a false reading.
If the elements read OL, then they are bad. Also, check to see what the voltage is to the heaters. Ensure the voltage supplied corresponds with the unit dataplate.
Jan 09, 2010 | Heating & Cooling
I have to dry the same load two or three times, not enough heat
Couple of things can cause this. Let's do the easiest first:
Restricted Air Flow- Unplug the dryer, and disconnect the duct from the back of the dryer to where it goes outside. Take the hose outside, and clean it out. Inspect the rear cavity of the dryer and the louvered vent where it exits the house. Clean both of these too. Pull out the lint screen. Remove any debris below it. If you found a lot of debris in the duct or elsewhere, this was probably the problem.....Reassemble....
BUT, if not,
(The harder of the two)----Broken Heating Elements- Elements are nichrome wire coils, same as the stuff in your toaster, but on a grander scale. They can wear out over a period of time. There are two ways to check them. The first way is to gain access to the terminals in the back, and test each coil for continuity. If it tests open, the afflicted coil needs to be replaced. The second way is to gain access to the coils and visually inspect them. Any damaged coil should be replaced. Coils are readily available from any appliance parts supply house, and are pretty inexpensive.
Hope that this helped. Best Regards, --W/D-- please feel free to rate this solution. thanx!
Aug 01, 2009 | Whirlpool Dryers
Dryer not heating hot enough to dry
Check for a clog in the piping, Make sure the squirrel fan you replaced not backwards, also visually check an see if the heating element is glowing completly red, if not it's probley getting only 120 volts, not getting 240 volts, if that be the case you'll need a new switch. There are about three switches that could cause that problem, the high temp switch, low temp switch or the timer switch.
Apr 11, 2009 | Crosley CDE6000 Electric Dryer
Want heat up
The first thing we must determine is the type of dryer we are servicing. There are only two types; Gas or electric. If your dryer is electric, meaning it uses electricity instead of flame to produce heat, step one is to verify that the breaker to the dryer's electrical circuit is fully on. Since electric dryers require 240 volts to run, their circuit is run through a dual breaker switch. Sometimes only one half of the breaker switch will be off or fail which will supply enough power to make your dryer tumble but not enough for it to produce heat. Pop the breaker to your dryer off and on again and then see if the dryer will now produce heat. If it does, then have the breaker replaced. If it doesn't, you can verify that the dryer outlet is fully powered by testing it with a volt meter, You can learn how to use a volt meter here. If the outlet is fully powered then the problem definitely rests within the dryer.
Let's next deal with the failure common to both types.
You will need a continuity tester for this process.
After you have removed the power from your dryer and shut off the gas, you will also need to access the internal workings of your dryer. Directions for achieving access, specific to your brand, can be found here.
Most dryers have a thermal fuse located in the exhaust path. Depending on your dryer, the fuse will be found toward the front or the rear of your unit. Generally, if there is a removable back on your dryer then that is where you will find the fuse.
The two most commons thermal fuses you might find are shown in Figure 1. They are each roughly 1" in size. You will notice that the contact points are easily spotted for a continuity test.
In older units and some electrically heated units you will find a series of thermal fuses, looking like small tin cans, at various points along the heater assembly. These will also need to be tested before you can rule out thermal fuses as your problem. If any of the thermal fuses fails the continuity test, then it needs to be replaced. You can find reputable parts dealers at the top of this page.
Electric Dryers After proving your thermal fuse(s) is/are good in your electric dryer it is time to move on to the next most likely possibility, the heating element. A typical heating element is shown in Figure 2. The element, as are all dryer electric heating elements, is comprised of metal coils supported on a framework with two contact points where wires are connected to the rest of the dryer. A break in this coil will stop the dryer from being able to create heat. Test the two contacts for continuity. If they fail, then you need a new heating element. You can find a diagram showing where each brand tends to place its heating elements here.
If both the thermal fuse and the element show continuity it is time to call a professional to service your electric dryer.
window.google_render_ad(); Gas Dryers Gas dryers use a burner system to create heat. This system has a number of parts that are known to fail over time. Some you can test, some you must simply rely on symptomology to form your decision to replace or not to replace.
In Figure 3 you can see an entire burner assembly with the various parts labeled. Not all of these parts can be tested with a simple continuity tester. An ohm meter is now required to find your problem part. Directions on how to use an Ohm meter can be found here.
The parts prone to failure in your burner assembly are:
  • Igniter
  • Coils
  • Flame sensor
A burner operates in a fairly simple way. Once the motor is turning, centrifugal force closes the Motor Switch allowing the electricity to reach the Flame Sensor. The Flame Sensor allows the electricity to reach the Igniter, allowing it to heat up to a temperature high enough to ignite natural gas. Once the Igniter is hot enough the Flame Sensor breaks the Igniter circuit which allows the electricity to run through the Coils that open the gas valve. Gas then flows out past the Igniter and catches fire and the heat is drawn into the airflow within the dryer.
Jan 12, 2009 | Kenmore 659 Electric Dryer
Gas dryer
Welcome jessegonzales
Check the outside vent leaving your house does not have a screen on it.
Take the screen off. Even half blocked and the dryer will not dry well.
Possible solutions
1. Defective Heating Element
The heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
The normal method for checking a heating element is to check it continuity. With the element unplugged you can check the continuity from one wire post to the next. If the circuit is open, thent he heating element is faulty.
However keep in mind that the element could be shorted to the case as described above. In this situation it is possible to have continuity, but the element still be the source of the problem.
Let me know.
Please remember to leave a rating
2. Defective Heating ElementThe heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
the heating element is faulty.
3.Defective Thermostat
The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
4. Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
One of these will solve the problem!
Thank You
Huuum.
Jul 29, 2008 | Frigidaire FGQ332ES Gas Dryer
Heating element on GE range stove
if its a plug in coil type element then you need to check the terminal it plugs into to see if its burned or the connections are spread or replace the switch no you dont need a new range
May 25, 2008 | Kitchen Ranges
Estate TEDX640JQ Electric Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
