Question about ASUS A8N-SLI Deluxe Motherboard
About a year &1/2 old....Install all new parts,power supply,video card,etc,. I can not get it to come up...no signal .Does this board come with a warrenty,also where do I send it to get repaired
  • 728 Answers
All ASUS motherboard purchased after November 1st, 1999 will carry 3 year warranty services. ASUS product warranty is based on the serial number printed.
Note: Warranty void for user removing serial number sticker on the motherboard .
If you want to repair it you'll need to take it back to the place that you purchased it from.
However, I have a suggestion first before returning it.
Take the new parts off and put the old ones back on, it the computer boots, then it's something about the new parts that are either not compatible, or they weren't installed correctly. You should check with ASUS.com and see if they support that PSU voltage and that video card first, because it's a nice board.
Good Luck
Mark
Posted on May 13, 2010
Just installed mobo ms-7091 m atx but find it as no video out ports how do i get a picture.i know its old but its my first attempt at building pc can i just install a graphics card.
I found the user manual here :
http://217.110.237.70/Manuals/Medion%208383XL%20mit%20MS-7091.pdf
Your motherboard provides 1 pci-express x16 slot, so you will need to install a pci-express video card.
Try to get a video card that doesn't need to be powered by the power supply. There are some out there that don't need to be powered, but .....
Most, but not all, pci-e video cards need to be plugged into your main computer power supply to work. If your power supply was designed to power a pci-e video card, it will have a 6 pin pci-e power connector to connect to a pci-e video card. If your power supply doesn't have this connector, you should replace the power supply with one with the pci-e power connector.
Sep 10, 2011 | Computers & Internet
When I plug component in to component 1 or 2 on my LG flat screen 42", sound is perfect but the picture is black and white and grainy-like a bad connection. This is consistent with both sets of...
This is a common problem for the 5-8 years old LG LCD TV, the problem is a defective main board, due to the new part dried out sources, the only way to do is to re-flow the soldering on the main board yourself by using your kitchen oven, this is the procedure:
Re-Flow Soldering Procedure for LG Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Apr 21, 2017 | LG 42 in. Flat Panel LCD HDTV
HI, MY RADEON 9800 VIDEO BOARD IN A TOWER BUILT IN 2004 HAS FAILED. THE SIX-YEAR OLD POWER SUPPLY IS A 380 WATT "PREMIER" AND I AM RUNNING THE AGP VIDEO CARD ON MICROSOFT XP HOME SP3. MY PROCESSOR IS A...
Since you have to purchase a new video card then I would go ahead and get one and see what happens. Worst case, you'll have to go buy a bigger power supply.
Oct 08, 2010 | Computers & Internet
Only power on in lcd.no disply and etc
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Jun 14, 2010 | IBM ThinkPad T30 2366 Notebook
Lcd has audio only no video from any input source
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 06, 2009 | LG 47LG50 47 in. LCD HDTV
My pc cannot turn on.
Get yourself a new one with new power supply new quad core new hard one terra evething new for a few dollars time change computers are something very different nowadays nothing to do with 10 years old machines....enjoy todazy life is not forever...;
Aug 19, 2009 | HP Hewlett Packard Pavilion Slimline...
GA-8IHXP won't boot... VER 3.0
The next thing I would check is a close inspection of all the bad capacitors on the board. If you need an idea of what they look like check here.
May 23, 2009 | Gigabyte GA-8IHXP Motherboard
Faulty motherboard?
bullnosestep
It is possible that the new (secondhand graphics card) was faulty and sent an incorrect voltage to part of your motherboard (frying it). However in my experiance it is not likely, I have installed and un-installed 100's of video cards over the last 10 years many of them faulty and only on one ocassion did it ever damage the board.
Things to try:
Double check (triple check) that your card is seated properly in the pci-e slot, this is one of the most overlooked things and is one of the most common problems when installing a new video cards. It may be drawing power from the slot but could still be slightly out of line.
Also most new ish psi-e card require an additional power supply direct from the PSU, did you connect this up if needed. (don't know what make the graphics card is so just in case)
Remove the cards and check the slot for dust and dirt, quite often when you remove an old existing card you can dislodge dust/durt from around the slot pushing it into it, thus making a bad connection to the video card. Blow the slot clean with a compressed air cleaner, can should cost £5-£10, don't use vacuum on the motherboard as this can cause extreme levels of static.
Are you sure you didn't knock a component on the motherboard during installation?
If you have tried all these things then you may have a damaged board. You could take it to a repair outlet to check the board over. They would be able to check the voltages etc... and may be able to locate the trouble.
The Pci-e slots can be replaced and re-soldered but it is a very skilled operation, to be fair you would be much better off buying another board. Lets face it, the slot is probably ok, you may have blown something elsewhere on the board.
Hope this helps and let me know if you solve the problem
Bri
Feb 01, 2009 | Computers & Internet
Signal to monitor goes in and out, mostly out
Hopefully, it is just the on board video that has gone bad, and not the motherboard. When you install a video card on a PC, that has on board or integrated video, you will need to access the BIOS screen on start up and disable the on board video. That way the video signal will come from the new video card and not the on board video.
I hope this helps,
Eric
Jan 18, 2009 | Gateway GT5220 PC Desktop
Pc starts and runs but wont boot up monitor shows no signal
1) When you turn on the computer, watch and listen for:
a) power supply fan, (power is on)
b) chassis lights (power is on)
c) ticking sound during memory test
(the BIOS POST is running)
d) beeps or rhythmical error codes
(POST failed, bad CPU, CHIP set, memory or video)
e) Monitor either comes on, displays garbled video,
displays a No Sync or No Signal message...
No depending on how far it gets:
Check power supply, cables etc.
Check video cable.
Check monitor with a different PC
Now unplug the power cord, with the computer still
on, this will help drain any internal capacitors.
Wait 5 minutes, then shut off the switches,
and open up the box. try the following,
one at a time:
2) Remove all I/O cards except the video card,
and don't plug them back in until the problem
is fixed. Unplug all the ribbon cables from
the mother board as well:
Hard drives, CD drive, floppies etc.
Make sure you make notes about how to plug it
back in, and cable orientation !!!
0) Re-seat all power cables: Red, Black Yellow harnesses.
1) Unplug and re-seat the video card
2) Similarly, re-seat all memory SIM/DIM modules,
3) Re-seat the CPU
4) Replace the video card
5) Replace memory, CPU or whole mother board,
Plug the good parts back in one at a time,
and test the machine.
Save for the power supply, there really is NO way to test
and isolate a bad module except by swapping/ trial and error
because of inter-dependencies.
For example a bad I/O card, any I/O card, can short circuit
the I/O bus, causing all other plug-in cards to stop working,
or even the main mother-board to freeze during the POST.
A bad power supply ditto.
A bad memory chip ... ditto.
The type of electronic instruments required to actually
test modern computers running at Gigahertz speed cost
hundreds of thousands of dollars, some cost millions, and
are only available to hi end manufacturers
Even the power supply will not power up for a voltage check
if the mother board is bad, although you can use a jumper
on the green wire to ground to force it on, when you unplug
the power connector from the mother-board, if you are brave.
Computer shops carry a lot of spare parts, and their service
department has gutted computers rigged up as test jigs.
They trouble shoot your system by either plugging your
stuff into their jigs, one at a time, or by plugging known
good components into your computer until the problem
is fixed.
This if of course possibly dangerous, since one bad part
can also fry other good parts that plug into it, or that it
plugs into. The compute shops, of course charge you
enough to make up for this.
If a computer is partially operable, it is also possible to
run software diagnostics.
If not, swap and pray is the only way.
Hope this helps
Please rate my answers, martin.
Jun 25, 2008 | HP Computers & Internet
ASUS A8N-SLI Deluxe Motherboard Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
