Question about RTO Construction Bobcat by Woody Click
Hello,I have a 1972 bobcat that is weak on one side.The lever to move the cat back and forth on the right side is sloppy and does not responde very well.Is it possible to adjust the chain by pulling off the two caps or do I need to remove the plate to adjust chain (if thats whats wrong with it.Any help wpould be great! Thanks for your time.
Sounds like a clark 610 they have drive clutch on each side of machine there is a very large nut (cover) on each side of machine undo this there will be a split pin in a castellated nut remove pin adjust nut clockwise a little replace pin and test hpefully this helps
Posted on May 19, 2010
Bobcat 773 excavator, blade and swing is weak everything else strong
if it has electronic controlled valves , check for power to the solenoids not opening the valves correctly
check valve and lever adjustments for correct operations
Apr 24, 2017 | Bobcat Garden
1998 bobcat skid steer 763 has a surge problem
on a 1998 bobcat 763 y
There adjuster bolts on either side of the control levers. To access these you must focuse. Your attention to the bottom. Of control......turning the adjusters left or right will
Excellerate or decrease the drive speed.of left or right traxs or tire's
Feb 11, 2017 | Sewing Machines
My 773 bobcat broke down in the worst spot, is there a way to free up the wheels for quick moving?
short of knocking a pin out of the drive chain you may get it to move if you hold the lever in drive while it is pushed by something big
that may hold the valves to the drive motor and allow it to turn
call bobcat service for a proper answer as they will be familiar with the hydraulics and have to move dead units around the shop
May 08, 2016 | Bobcat Garden
Bobcat skid steer
Depends what model you have. I suggest you do a Google with 'bobcat skitsteer problem'
Jun 01, 2014 | Computers & Internet
Where is the fuse box on a 753 bobcat
Depends on serial #. Should be in the engine compartment right side lower next too bottom door hinge in plastic covers two of them you will see the wiring harness going into the back of them. Relays are above battery.
Oct 01, 2012 | Bruder Cat Skid Steer Loader
Left front clunk noise over the bump
most likely bad strut /shock ----grab tire at 3 and 9 and move back and forth if sloppy , noise or loose check idler arm and tie rods ---grab top of tire and move back and forth if loose check control arms and ball joints push down on fender if bouncy or makes noise check strut/shock for problem
May 13, 2012 | Cars & Trucks
Eureka 2998az uno. Unable to remove dust cup.
The lever underneath the dust cup needs to be moved from the right side of the vacuum (viewing from the front) to the left side of the vacuum. The dust cup should then lift up and out for emptying. If the lever does not want to move all the way to the left it might be broken or jammed. If this is the case my suggestion would be to spray some WD40 into the lever area under the dust cup and try working the lever back and forth until it is freed.
Feel free to get back to me if you are still having trouble.
Paul
Sep 19, 2010 | Eureka Vacuums
Bobcat 553 f - traction lock problem...help
sounds to me like a bad connection or a weak solenoid causing the voltage drop. a good alt charges at 14.25-14.50. it takes voltage to open solenoids not close them.
Jul 19, 2009 | Bruder Cat Skid Steer Loader
Typewriter problem
It could be a bad carrier return motor or the carrier is stuck . Turn it off and try to move the carrier left and right it should move with light pressure if it don't try wiping the round rail it slides on with a light oil then work it back and forth a few times repeat until it moves when turned on.
Jul 24, 2008 | Lexmark Wheelwriter 1000 Typewriter
RTO Construction Bobcat by Woody Click Logo
407 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
