Question about Haier HDN305 Dehumidifier
Fan running When I turn the dial on the dehumidifier to the on position, the fan runs, but it is not taking any water out of the air. It never fully engages like it did in the fall. (I had the unit turned off all winter). Is my machine broken?
  • Haier Master
  • 43,501 Answers
There are many reasons for a dehumidifierfan running - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 12, 2010
The compressor and fan are running, however, there is no water coming out. RH is 70, temp is 66. This is after replacing a blower that had already seized up 2 years ago.
The dehumidifier should be removing water at 66F 70%rh.
First make sure that the compressor and fan are running. If they are, then turn the dehumidifier off and unplug the cord from the wall outlet. Next remove the front cover from the dehumidifier. Examine the evaporator coil (about 1/2 way up) beneath the plastic heat exchanger and above the stainless steel drain pan.
If the evaporator coil is cold and completely covered with frost & ice, the defrost thermostat may be defective. Replace the front cover. turn the humidity dial to "off". Plug the dehumidifier in to the wall outlet and set the fan switch to on - the fan will run (no compressor). Run this way for one hour to defrost the evaporator. Now adjust the humidity dial to your desired humidity and keep an eye on the dehumidifier. If it freezes up again and does not automatically defrost, the defrost thermostat should be replaced. Call the manufacturer at 1-800-533-7533 for parts and instructions.
If the evaporator coil is (mostly) warm and free of frost and ice, it is likely that some of the dehumidifier refrigerant has leaked out. this type of service should be done by a (refrigerant) certified technician. Call the manufacturer at 1-800-533-7533 for help with this service.
Aug 20, 2013 | Therma-Stor Santa Fe Dehumidifier
My humidifier has stopped dehumidifying while the unit itself is running. It simply does not take the water out of the air even though the motor is running, sensing the humidity of the basement. Is this...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Apr 23, 2011 | Whirlpool AD50USL Dehumidifier
Should the dehumidifier be blowing air out? It is
Unless the water level sensor is not working and you have the humidity setting low enough to call the fan should be running. If not then check water level sensor or float control to make sure they are working. Make sure the float is free to move if so equipped.If not clean and free up float.I would turn control dial up all the way and see if you can hear it trying to run. Turn it up and down several times.Also if you have a volt meter check to make sure you have incoming power to control and fan motor. Before I spent the money on a new motor I would bypass control and wire straight to motor.Try to isolate problem by process of elimination instead of just replacing parts till you find the right one. I have done this to many times and ended up spending more in parts and alot more in frustration,then the unit was worth to start with. Thank you.
Apr 17, 2011 | Maytag M3DH30B2A Dehumidifier
Compressor stops at proper humidity % but the fan keeps running.
Dehumidifiers are built that way. They keep moving air so it is able to keep any change of conditions moving around the room. On a dehumidifier, it the fan stops, your unit will short cycle becasue water will naturally evaporate from the water tank and it would turn on, then off, then on then off. The way it runs now is fine. Running the fan 24 hours on your dehumidifier cost nickels a day. Just let run.
Sep 28, 2010 | Danby DDR2504 Dehumidifier
Fan runs, seems to work ok... but not pulling water out of the ai
There are many reasons for a dehumidifier tto not work or collect water.
heatman101
Apr 16, 2010 | GE AHK40LK Dehumidifier
Not removing water and says tank it full
I just had one giving me the somewhat the same problem. Upon taking it apart I found that the entire inside was filthy. This thing runs in a work area in my basement and sucks up all of the dirty air. When you take the water out of the dirty air you have nothing but the dirt and the water. When you mix those together you get mud which is what clogged everything up in mine.
Dehumidifiers need to be clean on the inside to run properly especially all of the fins on the condensor. You will probably have to take it apart and clean it. Concentrate on the fins and the water collection areas. Dehumidifiers remove heat from the air which causes the humidity to collect on the condensor. As it collects it turns into water droplets. Gravity pulls the water droplets into the water collection areas and that flows to your tank. There is some sort of float in your tank that lets the dehumidifier know it is full and shuts it off with some sort of switch. It does this so it does not just keep running and eventually pour water onto your floor. It sounds like your switch and/or float is stuck. Find the float and switch and manually work them to make certain they are working freely, clean if necessary.
If the dehumidifier does not remove water like it should it is probably not getting good airflow. There are ice sensors on the evaporator that tells the compressor to stop working. However the fan will still run to pull warm air across the ice so that it melts, goes into the water collection area and into your tank. Some of these ice sensors work by measuring air flow. If there is no air flow or very limited air flow the sensor will tell the compressor not to work. The fan will run again to melt the ice so that it melts and is removed. If your condensor is dirty and does not allow the air to flow, this could cause your problem.
Mar 24, 2010 | Danby DDR6588EE Dehumidifier
Dehumidifier comes on runs for hours but does not dehumidify. The water pan is empty.
is there a setting ?? Dehumidify ??? as opposed to "Fan" if so set to Dehumidify...also turn up the dial to a higher number.....Is the element in the back Cold???? If on Dehumidify . turned up high and the element is cold...then you have a refrigerant leak and not worth fixing unless its under warranty
Oct 24, 2009 | Kenmore 54501 Dehumidifier
The unit turns on and sounds like it is running,
Your coil temperature has to be below the dewpoint of the air in the basement to remove the moisture. If you can set the temperature lower or the fan speed lower it will help.
Aug 08, 2009 | Whirlpool AD40DSL Dehumidifier
Will run but won't take moisture out of the air
It sounds as if the fan motor is running, but the compressor is not.
Apr 05, 2009 | Maytag M3DH30B2A Dehumidifier
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Dehumidifiers Logo
111 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Michael Vincent Cruz
Shehu Pro
Shehu Pro
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
