Question about Welding Tools
Have a Miller big 40 welder and the engine won't turn over
Have a Miller big 40 welder and the engine won't crank (locked up) water froze this winter, engine won't turn.
    Brigadier General:
  • 4,088 Answers
I'm not familiar with this particular unit--do you mean to say that the cooling system froze during the winter? If so, and the engine has overhead valves, the cylinder head, block, or both may have cracked causing water to leak into the cylinders which would have rusted the rings and cylinder walls (together). You are looking at major overhaul or even engine replacement (not what you were hoping). Good luck!
Posted on May 12, 2010
Testimonial: "it was already what I had guessed:)"
You have a set of points in the front of the generator part, next to where it connects to the motor. loosen that cover & slide it back and you will see them, take you a fine piece of sandpaper & smooth the carbon side of those brushes, just as you would in a starter. You can crank it up while you have that cover slid back & you should see little sparks from the brushes..this also will fix your 110 too
Posted on Feb 04, 2013
Engin boggs down while welding
have you had the cables tested,welding weares them out.how old are they a welder is like a big old coil or armature the contact points on it gets corroded causing it to work harder causing your bog
Apr 08, 2012 | Miller Trailblazer 302 Welder Generator...
I have a Miller big 40 bout an 87 modle that runs and welds great but wont idle down. Any thoughts?
There is a solenoid that controls the idle speed and the run speed- it is stuck in run speed. It may be a binding linkage, it may be bypassed by a previous owner.Chances are, as the idle relay is controlled through a load sensor on the control board and it may simply be a wire is off, damaged, or the solenoid is stuck.
There were a few different engines available for that model so exact connection will vary,
This the main manual
http://www.millerwelds.com/om/o450n_mil.pdf
The manual for the engine option you can scroll down to the "Big 40" in the list and just below that are the manuals for the different engines used.
Mar 26, 2012 | Welding Tools
I just started up a Miller Big 40 welder after 18 years, it runs like a charm, but the 110 plug is dead and there is no arc when trying to weld.
After 18 years, the welder has either lost its residual magnetism (which allows the output voltage to ramp up) or the voltage regulator is defective. Another possibility would be the brushes for the field not contacting the rings like they should - damaged brushes or weak springs. Contact Miller/ Hobart for a service manual, these checks are relatively easy to perform. The manual will give you specs that can be used for go or no go testing.
Aug 21, 2011 | Garden
I have a Miller Big Blue 251D and while welding it died and won't restart.
Hi:
Have you check the fuses? Probably your machine experienced an overload. Check your owners manual on the troubleshoot section. Here's the link to the manual.
http://www.millerwelds.com/om/o480ac_mil.pdf
Good Luck
Jun 15, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Field wiring taps - wire 480 or 208 3 phase need schematic
Hi:
Follow the link for the trailblazer owner's manual, check section 10 for wiring schematic.
http://www.millerwelds.com/om/o4426ab_mil.pdf
If this was useful to you please vote. Thank you!
Feb 24, 2011 | Miller Trailblazer 302 Welder Generator...
Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Jan 23, 2009 | Welding Tools
Welding Tools Logo
328 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
