Question about Microsoft Windows Vista Ultimate Edition
Help me !!!!!!!!!!!!!!!!!!??????????????????????????
How to maintain my desktop so that it runs smoothly and fastly?
And how to make my desktop extremely beautiful without spending money.
    Scholar:
  • 47 Answers
Hi Subranil,
Please let me know whats your RAM Size and CPU Speed. I shall be able to tell you a few tricks post that if they are feasable with your config.
Regards,
Gr8solver.
Posted on Mar 29, 2008
SOURCE:
Dell dimension won't boot up from new harddrive
check ur boot device setting and re install the os, to make ur os smooth and fast run registry cleaner reg in out
Sep 13, 2010 | Dell Dimension 3000 PC Desktop
Tip
How to maintain the speed of your desktop computer
If your computer has excellent specs then you're lucky. It is also important to note that as it ages, it can also be compared to us humans because their effectiveness and speed deteriorates. However, there are ways in which you can maintain its speed or at least make the deterioration process slower. Here are some tips that I also do with my own computer.
1. Upgrade or repair your Windows operating system. Whether you’re online or not, your PC is vulnerable to viruses esp. if you don’t Deep Freeze your drives. If you already like your OS then a repair is a better option in order to patch loopholes or performance glitches.
2. Have a fast and reliable antivirus. The one that I can recommend is the Avast because it scans really fast and you have the option to delete or move the viruses to virus vault without corrupting the programs. And update your antivirus regularly or auto-update it. You also scan your PC regularly and turn it on always. After scanning completely, you restart your PC in order to totally remove the viruses and detected threats.
3. Have as few desktop folders only. Delete or uninstall files that you don’t need and use like duplicate files. Keep/organize your personal files to drive D only. Keep the drive C just for your necessary programs.
4. Empty the Recycle Bin after deleting files.
5. Avoid using animated desktop wallpapers.
6. Stop or quite all unused applications. You just can right-click on those icons at your taskbar.
7. Clean your CPU with a blower/vacuum cleaner at least once a month and blow the dust away. It helps your CPU runs fast.
8. Upgrade or add memory. This surely makes your PC runs fast.
9. Check your PC’s ventilation. Overheating makes your PC runs slow. You can also use your electric fan in addition to your built-in computer blowers if you don’t use air-conditioner.
10. Use only fast browsers. I personally recommend Google Chrome or Safari.
11. Install ‘Cheat Engine’ and run it to any program you’d like to speed up. It makes browsing faster.
on Aug 21, 2010 | Computers & Internet
Tip
Caution For Desktop User.
Dear all users,
Pl keep your Desktop For smooth working.
1) Maintain your Electric power into 230v to 235v.
2) Maintain your Earthing into 0 to 3v.
3) Dont install non require software.
4) Maintain Your Antivirus updated.(15 day to 1 Month)
5) Dont install pen driver (when suffer from one and more desktop).
6) Check for Viruses in Weekly Schedule.
7) Shut Down Properly.
Regards,
Ravindra Shah.
on Feb 26, 2010 | Computers & Internet
WHEN PLAYING ZUMA DELUXE IT SEEMS TO BE JUMPING NOT RUNNING SMOOTH? CAN YOU HELP ? YOU KNOW INSTEAD OF ROLLING AROUND SMOOTH IT'S JUMPIE.
yes my freind this sounds like a problem with gfx card what one are you using was it running smooth ? if its low on memory then could be needing upgraded
Apr 19, 2010 | Computers & Internet
HI, I CANT RUN YOUTUBE SMOOTH AND FAST ON
Yes, provided you have a good broadband connection.
Please send us your feedback & vote to help us help you as it should be.
Feb 12, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
Tip
How to make your pc work fast
If you want your pc to improve speed then maintain these small tips.
1. Clean temporary file regulary (run/%temp%) delete all the things in the temp folder.
2. Scandisk your pc regularly.
3. Clear browsing histroy and cookies daily.
4. Avoid keeping files on Desktop.
on Jan 13, 2010 | Computers & Internet
Does windows 7 run fast on via processor?
Yes, Windows 7 should run OK on your PC
Jun 27, 2009 | Computers & Internet
Flashplayer stops and starts on gateway
How fast is your Internet connection?
Often, a "slow" connection cannot download fast-enough to support "streaming" from an online source.
Start playing the video, and press "pause", and wait one or two minutes. Then, press "play", and you should get a "smooth" playback.
Apr 01, 2009 | Gateway FX542X INTEL QUAD CORE 2 1TB...
My battery dosent last 1 hr from full charge new comp. 2 days old
you posted this in the desktop section I am assuming that this might be for a laptop? If it is then you might have gotten a bad battery. This does not normally happen, but it is possible.
Another thing that could be affecting it is the power settings. If you have the power settings set to maximum, then they will drain your laptop battery super fast, and about an hour sounds normal.
Another factor that might run a battery down fast is heat. If a laptop is used without proper airflow underneath it, it will drain the battery fast also. To solve this, you can use your laptop on a flat smooth surface, like a desk or table, or invest in a USB laptop cooler pad.
Dec 01, 2008 | HP Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
