Question about GE Nautilus 24" Built-in Dishwasher
My detergent despensor cup still has soap left in it after its done washing. Dishes are still dirty. Also is it a must that I use JetDry?
  • GE Master
  • 43,501 Answers
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " Great tips, will get the handy husband on this asap........thanks
Posted on May 12, 2010
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Dishwasher detergent cup does not open anymore....hence dirty dishes. Any help?
heatman101
Mar 31, 2011 | Frigidaire Dishwashers
Dishes aren't clean when they come out of the dishwasher. There is this whitish film on them. We use Cascade and Jetdry everytime.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
Help! My dishwasher runs thru it's cycles but when I open it I find my second detergent cup still full of soap and my dishes still dirty. I have an older maytag dishwasher but have never had this...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Aug 27, 2010 | Dishwashers
Soap dispenser not emptying during cycle. Dishes
Dishwasher Maintenance
heatman101
Jul 18, 2010 | Maytag Dishwashers
Last three loads have not cleaned my glasses - cloudy and lipstick still on them. Using JetDry and Cascade powder. What can I do to fix this?
You probably have a soap buildup. Try running it without any dishes in it. Let it fill up and start washing a few minutes, the open the door and see if there are suds. If there is, pour a half cup of cooking oil into the water and let it complete the cycle. That will clear the soap buildup. Aside from that, keep using jetdry and make sur the water going into the dishwasher is hot (run kitchen tap until it's hot before starting dishwasher to clear the line)
Mar 28, 2010 | Dishwashers
LEFTOVERS ARE STILL BEING LEFT AFTER THE CYCLE IS DONE. I RINSE DISHES BEFORE HAND BUT THERE IS A BLACK DISCHARGE ON THE BOTTOM OF THE TUB, AND SOAP STILL LEFT IN DISPENSER.
clean detergent dispenser drain hose could be kinked,check pump it could be dirty,is the water hot enough and is the detergent new?to remove spray arm un screw spray tower also clean out spray arm there may be food particles in arm as well as tower,try this out try washing unit with out dishes sometime vinegar or c.l.r will take care of problem but let it soak and don't add detergent.thanks
Dec 01, 2009 | Kenmore 24 in. 16362 / 16364 / 16369...
Hard sand substance on dishes after washing & Soap not dispensing
heatman101
Jun 19, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
76 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
