Question about Car Audio & Video
Connecting external component to J V C KD-G502
I wish to know how to change factory settings from CD changer to LINE IN have connected the Line Input adapter KS-U57 but cannot get the unit to change to Line In
  • Chieftan Jun 02, 2008
    I have exactly the same problem, I've purchased the adapter lead KS-U57 and plugged it into the rear of my KD-G502 head unit but cannot select the external component. Page 32 of the manual for the KD-G502 states that the unit is factory set to CHANGER to use the CD changer and that you need to change it to LINE IN to use the external component. How do you do this, I can't find the info anywhere?
Same problem I have!!! Please if you find the answer write to me at Thanks
Posted on Jul 02, 2008
  • DrKolev Jul 02, 2008
Jvc model kd-g502 in my car it has an ext adaptor ks-u57 at the rear of the unit for c/d changer or other ext device. To operate ext device "line in" must be displayed on the screen in order to...
1. Press and hold SEL till the preferred setting mode (PSM) comes up. 2. Scroll through the modes till you see EXT IN (You may need to set CD as the Source to see this.) 3. Adjust the value by moving the knob around the SEL button. 4. You should now see LINE IN.
Good Luck
And let me know how you went?
Mar 05, 2011 | JVC Ks U57 Line In Adapter
Installing a new stereo. I am trying to install a ''JVC KD-R210'' in my wifes 1985 BMW 535i, replacing a Sony CDX-R79 and in the trunk is a Pioneer 12 disc cd changer that was hooked up to the system. This...
There is a line level converter that would need to be purchased to that you can get the front speakers to work with the amplifier. The stereo already has rca jacks for the rear speakers. You can connect these straight to the amplifier for it to work. Bes sure that you use the blue wire to connect to the remote turn on for the amplifiers. Once you get the line level converter you will connect the wires and connect the converter using the RCA jacks. The question would be how was the 12 disc changer connected to the system. Would need more information on the changer in order to help with that component.
Mar 13, 2010 | JVC KD-S550 CD Player
Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Mar 16, 2009 | JVC KD-LH810 CD Player
Connecting an Ipod to a JVC KD-G310
Try this, you can connect thru CD Changer Input, that called J-Link. There is cables, that goes from J-Link to 3.5 mm jack.
So you need to buy on the ebay "JVC J-Link to 3.5 mm".
Best regards, Zhenya.
Jan 04, 2009 | JVC KD-G310 CD Player
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Does not switch to Ext Input
You have to enable "Line in" in the Stereo menu. Once you enable it when you press CD/CD-CH it should change to "Line In" and display Line in on the screen. Check the manual on how to enable line in...
Jan 30, 2008 | JVC Sirius KD-LH300 CD Player
Cd input?
I'm afraid it would be a complicated task to tap into the line input on the cd changer connector because the line input only becomes active when a changer is connected, so you would have to connect a device that would talk to the head unit to tell it that a changer was there
Nov 21, 2007 | Denon DCR-670RD
Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | JVC KD-G720 CD Player
Car Audio & Video Logo
1,006 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
