Question about Yamaha RX-V663 Receiver
I cannot get any video to show up. I have tried to hook it up with all available outputs to an optama projector and also a sony bravia lcd. using the HDMI to DVI cords. It says searching for connection and recognizes it for about 1 second then begins searching again. I cannot even access the yamahas on screen menu to mess with any settings please help.
  • 757 Answers
I am of the opinion that the video connections on receivers are little more than glorified "extension cords" with only a couple of exceptions reserved for standard definition monitors. Otherwise, connecting your device with video output directly to the TV or projector is the best choice...unless of course you have an outboard dedicated video processor, which the performance of cannot approached by any receiver.
However...to use the on screen receiver menu, the "monitor out" connection of any type to an available input on the TV will suffice.
Posted on May 13, 2010
I have a sony vpl vw60 projector. When it is turned on it shows only a blue screen. I do hear the DVD playing but only blue is shown on the screen. Not sure of the problem. I do have a replacement bulb...
Check out your output, they all show blue until you hook something up to them, make sure you have it hooked up right. write a post and let me know what you have hooked up to it.
Apr 23, 2011 | Sony BRAVIA SXRD VPL-VW60 LCD Projector
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Jan 17, 2010 | Sony BRAVIA VPL-AW15 LCD Projector
Fequency out of range
The unit has detected a video signal but can not decode it. It is likely that either the sending signal resolution is too high or too low. Try changing the video resolution to a different level and try again. If no signal appears to work, then the input card is defective.
Please keep us posted.
Dan
Dec 30, 2009 | Sony BRAVIA VPL-AW15 LCD Projector
Need to get sound for wii w/ sony bravia tv and sound system
There is usualy a 2nd channel for games like example - video 1 is video games but hear the tv, video 2 is videogames and hear Wii. Hope it helps
Nov 29, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
MY PS3 WONT SHOW UP ON DISPLAY
Turn off the PS3, turn on manually with your finger on the power (touch) button hold until you hear the first beep (powering on) and then hear a second. This should change the output of the video to what you are currently using. If nothing, then check your input channel. Hook something else in the same spot make sure the inputs work and hook up the ps3 and repeat the last steps if needed.
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
DVD is wired to the VCR and does not work
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
Dec 24, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Elmo slide to video projector
check the resolution. is your tv hd? the projector may not be.
Aug 20, 2008 | Elmo Projectors TRS-35XG 35mm 80 Slides...
Yamaha RX-V663 Receiver Logo
217 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
