Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Mah2400aww wont spin, codes OE, LE, and nF
Tried differnet cycles and turned power off no luck
IFIXALL
  • 868 Answers
SOURCE: spin cycle on my neptune MAH2400AWW shakes violenty
First make sure ALL four legs are 100% on the floor.Is this a recent problem that has come up?Has it been moved at all before this ??If this washer developed this all at once than you either had moved the washer out of its level,meaning that all four legs are not touching the ground firmly.The Neptune problem your having is un-common unless its on a pedestal.
Posted on May 14, 2008
SOURCE: getting nf code on final spin cycle
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Posted on Dec 13, 2008
Lanijo58
  • 72 Answers
SOURCE: when i am on spin cycle it stops and has a nf
This error code, pops up usually when in the spin cycle, your clothes are out of balance, too heavy of a load, or even at times it can happen with a too light of a load. Just stop or pause your washer and re arranged the items inside,
Posted on Jul 08, 2009
SOURCE: "OE" error message appearing at end of rinse cycle before spin
on the front lower left there is a panel. Pry it open from the top. Unscrew the large black round cap. Be prepared for water to rush out. There is a trap to clean out. To the left there is a rubber hose with a plug in the end. Remove plug and see if hose is clogged. Clean it out. Replace and it should run. If not, try blowing through the discharge hose in the back to make sure all is clear. If not??
Posted on Mar 10, 2010
richroth
  • 9472 Answers
SOURCE: nF code comes up and washer has just finished its
Posted on Jan 19, 2011
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
What is a le code and how do i fix it thanks cathy
sdfsf
sdfSorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 01, 2011 | LG Washing Machines
Error code LE
In new installations, this error can sometimes present because of a mis communication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
3 Thumbs - Helpful
3 Thumbs - Helpful
Dec 27, 2010 | LG WM1814CW Front Load Washer
OE code but will not drain and spin
LG Error quick list. Print it and post it near the washer:
IE: Water level
UE: Imbalance
OE: Drain problem
FE: Overflow
PE: pressure sensor
dE: door error
LE (with a a slash in the
middle of L. Thermister out
CE: Over amping
LE: hall sensor short
bE: Ball sensor loose connection
EE: eeprom out
PF: power failure
My Freebie manuals and repair notes are HERE
Dec 23, 2010 | LG WM2455 Front Load Washer
My washing machine is cannot spin ,it show error code LE
Nov 28, 2010 | Washing Machines
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Error code LE and OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Apr 12, 2009 | LG LDF8812 Stainless Steel Built-in...
Getting nf code on final spin cycle
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
