Question about Epson Aculaser C1100 Printer
64 bit driver for Epson c1100 to run on XP or Wndows 7
Can i get 64 bit up grade drivers for a c1100 epson aculazer printer to match windows XP Pro 64, or windows 7
  • 4 Answers
SOURCE: Epson C1100 - Vertical faint stripes on colour photos
see if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Posted on Mar 06, 2008
  • 5 Answers
SOURCE: Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
Posted on Dec 20, 2008
eric1121
  • 265 Answers
SOURCE: I am trying to get my epson stylus photo printer
Check out this link, it might help.
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-830U/Drivers-Support
Posted on Jan 22, 2010
SOURCE: epson aculaser c1100 not printing right hand edge
The problem may well be that the drum needs cleaning. There is a plastic flap on the rhs of the machine. Open that and you can pull a long lever out. You also need to let down the front cover and pull out the lever on the right hand edge that faces you. Then extend the long lever at the side as far as it can go and push it in and out a few times. This should solve the problem. Put the front lever back and close the cover. It took me ages to find this - Epson are not good at highlighting it,.
Posted on May 08, 2010
  • 186 Answers
SOURCE: how exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
Posted on May 23, 2010
Epson workforce 840 all-in-one. Driver installation fails.
Check the compatibility of the driver with the OS version:Windows 8 (32 or 64 bits), Windows 7 (32 bits or 64 bits) , Vista (32 b, 64 b), XP (32 bits , 64 bits). You should try to use the software that shipped with the printer. When installing, choose local printer (USB), or Network (Ethernet cable, or Wireless).
Oct 31, 2013 | Epson RX595 Photo All-In-One Printer
How do I make my epson stylus NX330 printer recognize my computer so I can scan to it.
  • http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=183403&prodoid=63091347&infoType=Downloads&detected=yes&platform=OSF_W_7-64
    Drivers and Utilities Combo Package 11/17/11 90.5 MB DownloadDescription: This file contains everything you need to use your Epson Stylus NX330 wirelessly or wired.
    This combo package consists of the following items:
    • Printer Driver v6.91
    • Scanner Driver and EPSON Scan Utility v3.781
    • Event Manager v2.50.00
    • Network Installer
    Compatible Systems: Windows 7 32-bit, Windows 7 64-bit, Windows Vista 32-bit, Windows Vista 64-bit, Windows XP 32-bit, Windows XP 64-bit
Not what you are looking for?
View all downloads for Windows 7 64-bit in the sections below, or select a different operating system above to reveal other downloads for your product
Nov 09, 2012 | Epson Stylus NX330 All-In-One Printer
I have an wireless Epson NX 230 printer 32 bit printer with Win 7 operating sys Emachine 64 bit desktop. Printer driver process says operating system does not support the driver. Test page does not...
Officially MS says it's not support, and Epson does not have an updated driver. Sorry.
If I'm running a 64-bit version of Windows, do I need 64-bit drivers for my devices?
Yes, all hardware devices need 64-bit drivers to work on a 64-bit version of Windows. Drivers designed for 32-bit versions of Windows won't work on computers running 64-bit versions of Windows.
Description: This file contains the Epson Stylus NX230 Printer Driver v6.91. The Epson Status Monitor 3 is incorporated into this driver.
Compatible Systems: Windows 7 32-bit, Windows Vista 32-bit, Windows XP 32-bit
Aug 30, 2012 | E-Machines Computers & Internet
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
WE WANT WINDOWS 7 EPSON PRINTER R230X
Epson Stylus Photo R230 6 Colour Inkjet Printer files Driver Printer Driver 6.52E
Windows 2000, Windows 7, Window Vista, Windows XP Posted: 24/11/2009
Click here Utilities Epson Easy Photo Print 2.23.01
Windows 2000, Windows 7, Windows 7 64-bit Edition, Window Vista, Windows Vista 64-bit Edition, Windows XP, Windows XP 64-bit Edition EPP_22301_EHKT.exe
Posted: 19/1/2011 Download
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
Prining with Win7 64 on a networked Epson PictureMate on XP
As you did not specify your printer's exact model, I would suggest to use this web page to look for the Windows 7 drivers for your printer:
http://www.epson.com/cgi-bin/Store/support/SupportWindows7.jsp?BV_UseBVCookie=yes
Both Windows 7 32-bit & 64-bit drivers could be found using this web page.
Dec 19, 2009 | Epson PictureMate InkJet Photo Printer
Epson Aculaser C1100 Printer Logo
855 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
