Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Tv comes on and then after a while the picture goes down to this scrunched up color lines in the middle of the set and sound goes off also. It is a Hitachi 60 inch big screen 1997 model
  • 1,476 Answers
Sounds like you have broken solde joints on the vertical/horizontal board. I have a tip at http://www.fixya.com/support/r4751428-fix_no_vertica_drive_problem which explains the problem and how to fix it. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 12, 2010
Picture comes on ok to my LN40C550 Samsung, then colored lines begin to appear through the middle of the screen, almost like a colored bar code
Sounds like a T'Con board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Samsung LN-S2651D 26 in. LCD Television
Turn the TV on and a minute after the picture comes on the picture scrunches up to the top of the screen and colors are distorted. It the goes black. I turn the TV off and on and the picture is sometimes...
try to tap your tv slightly at the side if it go back to normal operation you have a weak solder commonly in the main board try to resolder parts that is slightly hung.
Oct 15, 2010 | Sony Televison & Video
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
I have sound but no picture--just a colored line down one side and the text for the main screen scrunched up into a corner
Sounds like the deflection circuitry has failed. You will need to take the TV to a repair shop (or just buy a new TV). There are "no user serviceable parts inside" so don't try to repair it yourself.
Sep 18, 2009 | Televison & Video
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Picture goes dead after 5-10 minutes
You may have a loose solder joint causing this problem. If you can take it apart, you mihgt try spraying circuit cooler in various parts of the circuit but NOT in the high voltage or horizontal circuits.YOU MAY CAUSE AN ARC OR A COMPONENT TO SHORT SINCE THE SET HAS TO BE IN OPERATION WHEN YOU SPRAY. If you hit the bad connection the picture will come back on. When the picture zaps to the middle of the screen, is there just a bright line? If so, then you have a loose connection or a temperature problem in the vertical circuit. Stargazer
Mar 03, 2007 | RCA 27F530T 27" TV
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
