Question about SaniServ 401 20 Quart Ice Cream Maker
I have a saniserv 707a and the product won't freeze. The refrig line is freezing right after compressor switch.
My saniserve ice cream machine will not get freeze hard or freeze when u press the button on for the compressor to kick , it will not kick in.
Posted on Apr 21, 2014
3 Suggested Answers
  • 30 Answers
SOURCE: what brand compressor do saniserv use
Depends on the unit, goto to www.saniserve.com ,they can tell you the exact compressor by the model and serial numbers.
Posted on Mar 07, 2009
bobicehouse
  • 1524 Answers
SOURCE: We have a Saniserve df200
Compressor running ? If so sounds like a refrigrant problem
Posted on Jun 03, 2011
Hello I have a 8754 Taylor and having trouble with the (chocolate)left side of the machine.The product goes soft after I've served about fifty cones. this is what I've tried *installed all new o rings...
sounds like a freon like to me if the compressor is running for long periods and not freezing properly or you have a water pressure issue. if it is water cooled which alot are it is hard to realize you have a freon leak.
Dec 12, 2014 | Taylor Ice Cream Makers
I loaded the machine with mix and turned it on but machine keeps on turning but mix is still very watery
My small Business had this same problem. The first thing you need to look at is the product you are using. It turns out that if you are making your own soft serve. which Includes water and powder, it will save you a lot of time and stress to switch to cartons of soft serve that you just pour right in. It turns out that there is no consistency in powder icecream. the water will eventually separate from the mix, resulting in watery soft serve once dispensed from the machine. Next, if this isn't the prduct you are using then it can be other problems such as your compressor not working, or turning on when it's suppose to, maybe you have a weak motor, or your machine isn't set to the proper freeze level, Also, make sure that your machine isn't backed up against a wall or I between two other machines. These machines need to Obsorb cool air in order to work properly and not overheat . The machine's fan, which is located on the right side, needs to be have a certain amount Of space from walls or other machines. If this doesnt work you can always call a technition to come and check out the machine, I hope this helped, best wishes with your repair
Jul 16, 2011 | SaniServ 401 20 Quart Ice Cream Maker
I HAVE A TOGGLE SWITCH ON THE BOTTOM OF MY MACHINE. WHATS IT FOR???
I have been unable to locate the toggle switch in a SaniServ Operational Manual located HERE , I suggest you call and ask Saniserv what this toggle switch is for 800-733-8073
Thumbs up if this helped!!!
Jun 21, 2011 | SaniServ 401 20 Quart Ice Cream Maker
Looking for a manual for my Saniserv 407. Any info would be VERY appreciated!
I was able to get you a phone number where you can inquire about the manual you need 1-866-892-6344 and a website that sells this product.
http://www.instawares.com/saniserv-soft-serve-ice.ssm-407.0.7.htm
it appears to be distributed by a third party called instawares. good luck
Dec 29, 2009 | SaniServ 401 20 Quart Ice Cream Maker
Same Machine
In the 1990s SaniServ manufactured soft serve ice cream makers for slush puppy Corporation and call it freeze bee model A 501 which is the same machine as SaniServ model 501...........
if you go to www.saniserv.com or call their phone number at 317-831-7030 and give them your serial number they will give you all the information you need, when inquiring ask for technical help.
I have one and I really like it, does a great job, you need to fine the saniserv dealer closest to you for parts and supplys, they have everything you need.
Bob aviator state of Maine
Aug 31, 2009 | SaniServ 501 Twist 22 Quart Ice Cream...
Press the switches and nothing turns
Contact the manufacturer.
This sounds like something that you may have to get repaired (or, if not, the manufacturer usually knows all the little tips and tricks to get it working! :)).
Their contact number should be either stamped somewhere on the machine or in the product manual (usually near the back of the book). If you still can't find it, you can usually just do a quick internet search (just typing in the manufacturer name--in this case, "SaniServ"--and then "support" into Google usually helps).
Good luck! :)
Aug 22, 2009 | SaniServ 407 10 Quart Ice Cream Maker
Machine won't come on
Check and see if all of the wires are on the freeze/cleanout switch. make sure the switch is in the freeze position. There is also a torque switch in back of the unit where the belt is,the belt tensioner engages and disengages this switch to control the viscosity of the mix in the barrel.check to make sure the metal arm of the switch hasnt been bent so far that it will not move, and that it does not have mix in it. Also check the voltage to the contactor coil. if you have correct voltage at the coil, then it is a bad contactor.
Jan 15, 2009 | SaniServ 401 20 Quart Ice Cream Maker
Saniserve 707a margarita machine
The best thing to do would be to recover the 404a into a clean recovery jug,weighing how much you take out. Check the nameplate on back it will tell total ref charge. in either oz or lbs. then weigh the charge back into the unit. this is the best wayto verify if you have a proper charge.If the unit is low on charge then you will want to find and repair the leak as soon as possible.
Jul 13, 2008 | SaniServ 401 20 Quart Ice Cream Maker
What brand compressor do saniserv use
Feb 26, 2008 | SaniServ 401 20 Quart Ice Cream Maker
SaniServ 401 20 Quart Ice Cream Maker Logo
261 people viewed this question
Top SaniServ Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a SaniServ Ice Cream Maker Expert? Answer questions, earn points and help others
