Question about Oster Health & Beauty
Part list for a oster class 2 battery charger
Need a part list for a oster class 2 battery charger model 48951-005 circuit board is 42418-001 Rev. 3B. Part I need is F101 fuse is what it looks like
  • 313 Answers
SOURCE: works off mains and battery but wont charge battery.
replaced the circuit board where it meets the battery
Posted on Sep 19, 2008
SOURCE: Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Posted on Nov 20, 2008
  • 13 Answers
SOURCE: I have an old Oster
You can get a wide varity of oster clipper heads at Sally's Beauty Supply. I am not sure where you live but they are in most citys.
Posted on Jan 09, 2009
  • 32 Answers
SOURCE: battery charger on board doesn't work. Replaced everything, stil
try replacing the battery fuse
Posted on Jul 13, 2009
  • 84 Answers
SOURCE: Need circuit board for Goodman GMNP-060-3 Rev B Furnace
Go to your nearest HVAC supply house. They should be able to get you it.
Posted on Aug 06, 2009
Is there a fuse inside the xr 8600 power mixer?
I see 2 on the schematic..... F100 & F101 - could be board mounted? I don't have a unit to compare :-) Good Luck!
Dec 18, 2016 | The Music
What makes the on board charger not work an how cah it be tested to see if it is good.
There is a fuse in the charger and another in the chair for the charging circuit. Poor connections to the controller and at the batteries will do it too. If the batteries have been completely discharged, then the onboard charger does not have enough power to start recharging them. If that is the case, use an automotive 12 volt charger that has no automatic charging circuits in it to charge them individually. That means removing both batteries from the chair and connect the charger to one battery at a time. You can test the charger with the batteries disconnected and measuring the voltage on the wires you just took off the batteries. The voltage should be 28 volts or so if the charger is working.
Jun 29, 2015 | Jet 3 Ultra Power Chair
Hi need a battery charger for Europe 220V for the Model 784000 01a klippers, Where do I buy this!
Hi most oster replacement spares are available on our website anything not listed just contact us.
Feb 23, 2014 | Oster 76076-010 Hair Trimmer
I am looking to buy 2 new batteries for my power pro clippers model 48951-005, where can I buy them?
I too need the same batteries but Oster stopped making them and now if you want a battery to fit the female part of you set you need to buy a new battery with a new gizmo at the price of over $150 Making what you have worthless and making what you need cost more than two old batteries or a new machine all together. Its a real rip-off.
Sep 18, 2012 | Oster POWER PRO Cordless Clipper 76600-013
How to change a fuse in oster microwave oven
Unplug microwave, remove top," several screws" look to the right where the keypad control board is, now look down where the printed circuit board is, fuse should be near by clipped in, pop fuse and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 21, 2012 | Oster OGB61101 Microwave Oven
Charger not powering up, fuse is good?? what the f---?
Internal board fuse checked? This may/may not help?
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the usual 240 Volt AC. On the charger circuit board next to the transformer wire connection is a component marked F2; this is a 2.5Amp fuse covered with heat-shrink sleeving. This fuse had ruptured/blown. Also blown was Transistor Q1, a ''P'' Mosfet labelled IRF9Z24N and Schottky Diode D9 labelled SR560. Replacing these 3 items got the charger working again. NB Resistor R31 is only 0.1ohm - don't assume it's gone short circuit! NB. I'd presume that most other Makita chargers will have this heat-shrink sleeving ''camoflaged'' fuse on the input of the circuit board and it would definitely be worth checking if the charger has stopped working. Regards Roy
Oct 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Charger no light and wont charge
Sorry to give you my opinion, but these chargers are very delicate, I have 4 and can barely keep 2 going. My recommendation? Open it up and look for obvious shorts/loose wires, if no luck then buy another one and return the busted one as if it were the new one. You will end up with two working chargers. PS this is probably fraud...ha!
Matt Giantglobes.com
Mar 10, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
Oster 12 bottle wine cooler
You must remove the fuse from the circuit board to check it. More than likely it's blown. A continuity test while in the circuit will always show the fuse as being good due to feedback through the circuitry.
Aug 09, 2008 | Oster 12-Bottle Wine Cellar - Black
Health & Beauty Logo
158 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
