Question about Whirlpool GEW9200L Electric Dryer
My duet dryer spins but does not heat - Whirlpool GEW9200L Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
Hi, If you have a gas dryermy duet dryer spins but does not heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif imy duet dryer spins but does not heat - 2_bing.gif"http://www.fixya.com/support/t4734648-dlg5932w_not_drying_completely_hear_gas#">electric2_bing.gif..
There could be a number of different problmy duet dryer spins but does not heat - 2_bing.gif/>Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 12, 2010
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Dryer is spinning, but there is no heat. How do I
The Duet manual referenced below will help you with diagnostics.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Posted on Jan 17, 2010
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
vostendorp
  • 347 Answers
SOURCE: Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Posted on Aug 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: my front loading whirlpool duet
It appears your thermistor (thermocouple) or gas valve solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My whirlpool duet gas dryer won't heat up. Drum spins, but no heat. Is there any kind of a reset for this?
Too complicated to explain could be a bad heat relay on control board or an open thermal fuse you didn't say whether gas or electric meaning could be an igniter gas valve coils or a heating element
Feb 20, 2015 | Whirlpool WGD9450WL Laundry : Dryers
Duet sport electric dryer won't heat or spin, minute counter counts down
You will need to replace the "thermal fuse" located on the back of the dryer. Here is the part to order.
Nov 22, 2012 | Dryers
Whirlpool Duet WED9150WW dryer heats up but does not spin. The belt is not broken and door switch appears to be working.
If the dryer is on and everything is working except the drum is not turning, then the motor is bad. Here is the new motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
We have a whirlpool duet dryer and it will not heat up. I've checked for blockages and there doesn't seem to be any. It does spin but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 29, 2011 | Whirlpool Dryers
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jan 17, 2010 | Whirlpool Dryers
My whirlpool duet front load dryer is not heating up. The drum moves but there is no heat. how do I fix this?
Check your breaker. The dryer will spin at 120 volts but will not heat without the full 240 volts. If that's not your problem there are some fuses behind the bottom front panel that need to be checked, along with the heating element. You'll need an ohm meter for this. If its not your breaker, its best to hire someone. Good luck...
Nov 16, 2009 | Dryers
Duet dryer
be sure wires on back at ac connection are tight loose connections generate heat and will cause wires to burn also be sure they connected properly this problem usually falls under installation problems not dryer problem
May 28, 2008 | Dryers
Whirlpool GEW9200L Electric Dryer Logo
159 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
