Question about Vivitar VivaCam 8370 Digital Camera
The battery door has broke, it is just the cover and not the hinge
    President:
  • 2,976 Answers
You can get a new door from the manufacturer's website for a few dollars. It is a simple replacement, involving a few screws to loosen the case in the door area.
Posted on May 12, 2010
How do I replace the canon sd40 battery door. it wont stay hooked, looks like a pice broke off in the hinge
Ebay was selling one for a few dollars in working condition, you are better off buying a used one or a none working one making sure the battery door is good. You can replace the battery door but it will require you to take the front and rear cover of the camera off. You will have to take off the little screws all around the camera and the pry apart the front and rear case.
Sometimes you can use a pair of small needle nose pliers and just squeeze the ends of the plastic battery door inwards from the hinge and the battery cover should pop out. To install the new battery door you do the same, squeeze the plastic axle and push it into the cameras case.
Feb 11, 2015 | Canon PowerShot Cameras
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
How to fix door on hobart lxih dishwasher?
Check the door hinges.. if a hinge is broke or the door came off the hinge it won't shut.... now if the door won't stay closed then the tension bar that is on the door, connecting to the hinges is broke and you will have to replace it
Jan 26, 2013 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Kenmore Refrigerator 596.73503200 deli drawer cover hinge pin on right side broke off. Part #?
I would direct you to this link to find the part number you're looking for. I do not have one of these units to look at so am unsure which specific piece you'll need to replace.
Model 59673503200 KENMORE ELITE KENMORE REFRIGERATOR Parts
Nov 03, 2017 | Refrigerators
I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Dec 27, 2009 | Dometic RM2652 Refrigerator
Door hinge is broke on Bosch Axxis+ Front loader
There are 4 screws in the door that hold a plastic hinge cover on
.The door will then set into the hinge just fine (PLENTY OF ROOM) and then you put the hinge cover back on and screw the screws in to hold the door onto the hinge.You will likely need a 2nd set of hands to keep from breaking the door.
Oct 10, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Bolts broke on bottom drivers door hinge
a vw wreckers or dealer will sell you the correct hinge bolts with the year model on you
Nov 08, 2008 | 1998 Volkswagen Beetle
Cx7330, battery cover BROKEN
Remove batteries and memcard. Remove 8 screws, the screws on the bottom are smaller than the side screws. Rear cover will slide off, watch out for loose LCD screen. Two protruding slots on the bottom hold the battery cover hinges. Hold battery cover wide open and at an angle to snap hinges into place. Reinstall rear cover and screws.
May 29, 2007 | Kodak EasyShare CX7330 Digital Camera
Vivitar VivaCam 8370 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
