Question about Miele 23 in. Novotronic G841 Built-In Dishwasher
What would cause white residue on plastic? Plastic containers, black handles and high heat plastic material type utensils com out with a white powdery feeling residue on them. It takes scrubbing & hot water to remove it. I've tried 2 different types of powder, the 1st I had been using for over 3 years with no previous problems. Any thoughts?
    President:
  • 2,976 Answers
With the reformulation of detergents, it's becoming a common problem. You can try a liquid with water softener in it, and slightly hotter water. It might help. The environmentalists have made the manufacturers reformulate a lot of cleaning products to the point that, vinegar and water is almost as good as the newer detergents.
Posted on May 12, 2010
Are there biodegradable kitchen utensils?
Yes, several brands produce biodegradable plastic utensils made from bioplastic, a biodegradable starch-polyester material
Jul 16, 2013 | Home
Dishwasher is not cleaning the dishes, leaving a white residue on the bottom and front of the machine
Hi fmitchell,
White residue is normally caused if you use a very high heat setting. Reduce the heat and things should improve.
Also remember to check the Salt container at the bottom of the machine, replace salt if necessary.
Kind Regards
Jacques
* If you found this solution helpful, please rate my answer
May 26, 2011 | Dishwashers
Recently the dishes have a grainy feel and the glasses have white smears on them. Some of my kitchen cooking utensils which are made of a black material are all coming out coated in a white file
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 13, 2011 | Dishwashers
I made hamburgers and the first time the cups melted due to the grease that was draining off. I followed the grilling instructions per the manual and had a greasy mess to clean up. Now I have to find...
The plastic cup melted because it was touching the hot plates and not because of the hot oil!
It is a poor design but with careful use can be fully functional, plastic is used to keep the cost of this budget product down.
Sep 02, 2017 | GE 4 in 1 Grill / Griddle
My dryer wont heat or spin
Heat: thermal fuse attached to the exhaust duct on the back panel of the gas dryer,usually surrounded by a black resin material situated in a housing made of white plastic, if there is a lot of lint built up it will cause it to blow
Spin: belt , motor, switch
here is a website that will help:
http://www.applianceaid.com/gas_dryer.html#noheat
Oct 30, 2010 | Kenmore 73952 Gas Dryer
Plastic is melted onto the heating element. is this a problem? what should i do?
I am assuming the dishwasher is not working.
You will need to check where the plastic has come from. The temperature has to be very high for the plastic to melt. This can happen if the dishwasher heater has been on with no water in the dishwasher. Normally the controller should not allow this. Also the thermostat should cut in to prevent the temperature from going high.
Most likely it is not plastic but a problem in the wash pump which is causing some residue to circulate in the water and deposit on heating element.
In any case, try to scrape off as much of the material as you can and then run the dishwasher with a Finish dishwasher cleaning kit. The instructions are on the kit label.
Hope this helps. Please rate the solution.
Oct 10, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
My dishes are not getting clean, the plastic has a grease fill on it the glasses have food residue stuck to them on the inside. I had to put the glasses on the bottom shelf in order to clean them but that...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 15, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Plastic dishes and utensils have white film on them
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 03, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Miele 23 in. Novotronic G841 Built-In Dishwasher Logo
967 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
