A JVC AV-65WP74 has convergence problems. It is also bowed in from top and bottom. Is there more to this than just the convergence ICs?
  • Patrick McAlexander May 14, 2010
    I set convergence but it doesn't stay. How do I make it stay?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $300-$350. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 14, 2010
    i checked all resistors and found 2 open. Replaced them and the ics. Now when I manually set convergence using the remote what button do i push to "lock" it in? Menu?
    I found it on another remote. It the ok button.
  • 10,594 Answers
Replace convergence out ICs and also check +28V and -28V supplies to ICs at CN00P coming from power supply board.
Also check any faded color big resistor and if found, replace it with same ratings written on it.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on May 12, 2010
  • 4 more comments
  • Patrick McAlexander May 13, 2010
    Do you happen to know the part # for the convergence ics?
  • Shahid Electronics
    Shahid Electronics May 13, 2010
    Convergence output ICs are located on convergence board and part number is STK392-110 and circuit location number is IC804 and IC805
    Please click Part Store to see IC image and price info.
    Thank you. I found 2 open resistors also. I get my convergence completed but after I unplugged set and plugged it back in the convergence didnt stay. Is there a "lock in" button on the remote after setting convergence?
    Shahid Electronics May 14, 2010
    It calls "service menu" to adjust many things in tv but it is for qualified tech only and related service manual in hand is necessary because it contains default values of service menu.
    In my opinion, there are still few resistors that are either devalued or open. I would not recommend to go in service menu, please fix hardware of tv and convergence will be fixed automatically.
    OK, thanks.
I have a jvc model av-65wp74. my green convergnece wont align at all
Convergence ICs and resistors need replacement. Very common issue. The AV48WP74 -AV65WP74 convergence repair kit from www.tvrepairworld.com has the 2 ICs and associated resistors plus the CD with repair instructions.
Aug 16, 2011 | JVC AV-65WP74 Rear Projection Television
My jvc model# av-65wp74 the screen is bowed and the colors will not match up.i have put in two new convergence chips still no luck.
did you check the low ohm resistors. A JVC will almost always blow at least one and if the ICs are replaced without replacing the resistors the new ICs will fail instantly
Feb 26, 2011 | JVC AV-65WP74 Rear Projection Television
I have a JVC HDTV model AV-65WP74, i had my tv on overnight, woke up this morning i found the colors on the tv kind of funny and the tv is also showing double images. Please help. What to do?
The convergence ICs have failed. You can get the JVC AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com which has the ICs and resistors plus the CD with detailed repair instructions.
Nov 08, 2010 | JVC AV-65WP74 Rear Projection Television
AV-56WP74 the convergence is off. blue is way out!
You will need to replace the Convergence ICs and resistors you can get the JVC repair kit called the AV48WP74-65WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with instructions,
Sep 23, 2010 | JVC AV-56WP74 56" Rear Projection...
My JVC JVC AV-65WP74 Rear Projection Television is getting blurry ,and or, turning to double vision on the botton. Can really see it when there are words or writting on the bottom of the screen. Hard to...
2 Convergence ICS and some or all the resistors are dead.Know how to solders?Buy a covergence kit at websites Trepair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Jan 14, 2010 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 clicks and sounds like a heart beating and then turns off. what is the problem, how much will a repair cost?
it could either be convergence ics shorted or deflection board trouble
as to cost convergence 300 to 350
if its power supply 300.400
it would have to be isolated down to the exact location causing the problem
but usualy a great set to keep around
Oct 24, 2009 | JVC AV-65WP74 Rear Projection Television
Troubleshooting AV-65WP74
You need to replace the two Convergence amp ICs they are both STK392-110 thats a easy reapir on that model , But dont remove the rear panel with the power cord plugged in you will destroy the digital circuits. the Ics are up front behind the speaker grille. You can get new replacement Ics at the following link with free instaltion instructions with pictures. Here's the link,
http://servicemanuals.vstore.ca/
Jun 26, 2008 | JVC AV-65WP74 Rear Projection Television
Thank you
Check pico fuses in power supply with ohmmeter......
Check current-limiting resistors near convergence IC's.......
Measure B+ supply voltages ( use manual)................
Apr 08, 2008 | JVC AV-65WP74 Rear Projection Television
Thanks for the help
check the resistors right next to the ICs usually the 1.5ohm resistors will open when the ICs go out
Convergence
B+ voltages to run the convergence circuit missing == check power supply for open fuse devices..........................T.
Apr 06, 2008 | JVC AV-65WP74 Rear Projection Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
