Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
Dell e173fpf inverter board replaced it in Monitor. Light is on and stays on. No communication with PC now though. All connections the same..check rechecked. Light but no one home so to speak. Help! May be wires in wrong way. Have unconnected and connected so many times I don't know the original placement. Does someone have a diagram of the wiring placement and what else could I have done wrong? Original problem was monitor came on for 30 sec and then off. Could hear the pc was on but no light. Reboot, same thing. light on then off and could hear the pc startup mode..MicrowindowsXP
  • 11,361 Answers
Here are the service manuals, but I do not know which versions you have:
http://elektrotanya.com/?q=showresult&megnev=Dell%20&megnev2=e173&kategoria=&kat2=all
Does your board look like this: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Posted on May 13, 2010
Have a dell E152FPb flat screen monitor which doesnt stays black even when on light is green. have taken back off but no obvious bulging etc. what can i try to get some life back imto it please
The backlight controler board is faulty. You can try replacing any capacitors in this board even if they look OK. If this does not work then you need to replace the inverter board with a universal inverter board - you will need to work out the wiring details though.
Mar 10, 2011 | Dell E153FP 15" LCD Monitor
I have a Dell e173pfb monitor. i push the power button and green light comes on screen comes on for a second with no problem then the backlight goes off. I can still see an image with a flashlight though....
You need a new backlight inverter board. If you dissasemble the monitor you will see a circuit board with 4 2-wire connectors connected to it. This is the board you need to replace. Typically they run from $15 to $40. Usually just easier to replace the monitor. Another idea is to reduce brightness levels on the monitor in the menu while looking at it with your flashlight. Then power off then power on the monitor and it might stay on longer.
Aug 16, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Gradual diming of screen over the past month.
The speaker assmbly slide out, it has two fingers on it, see pictures here on what to look for inside: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | Dell E173FP 17" LCD Monitor
Dell monitor will come on but will not stay on. stays on 5sec
5 seconds? Hmm, too long for inverter driver turning into protection caused by bad lamps. Also too long for PWM controller in the switching power supply.
Rather looks like overheating of the FETs in the inverter, they are driving HV-transformers. Open the monitor, remove metal lid and observe inverter board. If PCB under and around these FETs is darkened, replace them.
These Dells hard to open. Take the foot off and unscrew plastic cover. Then using flat screwdriver with wide blade separate plastic halves of the case, starting from bottom edge and moving to opposite. It might be sweaty.
Sep 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
http://josepino.com/other_projects/?howto-repair-dell
goo dluck if you want it fixed for you let me know
Mar 22, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Flat Cable (P-Two AWM 20969 E221612)
you need to be patient because if you cant get it from the dell stores and still you can get it online you will need to visit a computer hardware vendor/ repairer who have thesame monitor but the monitor is completely damaged so that he can repalce it for you. but it is going to be expensive.
Dec 16, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPf lcd- no picture,steady green light
E173FPf Mfg December 2004
This E173FPF has changed much inside from the November 2003 E172fpb which had the famous 4 identical transistors 5707 that would tend to fail in pairs. If your newer E173FPF displays a green power light and fails to display a picture try replacing the 220uf25v capacitors at C6 and C26. Test them with a volt ohm meter and they will test Ok, replace them anyway. Radio Shack did not have the 25v so I used the 35v, display works fine now. There is an E173FPF repair kit with directions available on Ebay if you don't have a parts store in your area and would prefer delivery.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 14, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell e173fpf lcd monitor is grey
Sounds like the AD section of the board may be junk. I did the same thing - bought the board from lcdrepair.com.
I submitted an RMA request to get a replacement. The process was difficult due to the pdf form they make you fill out. Lots of errors and no good way to submit it, since it wants to use outlook, but the pdf isn't configured properly to do so. Seems fishy, but I'm giving them the benefit of the doubt for now. We'll see.
Nov 10, 2007 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
282 people viewed this question
Alun Cox
