Question about Nokia N95 Cellular Phone
You cannot get any thing on screen no picture or anything
I went to use my phone and noticed the screen has no display it only lights up ive tried turning it off and on and removing sim card but nothing is working it is still blank
    President:
  • 778 Answers
You could have a bad display (that would need replacing), or it could just be that the ribbon cable attaching the display to the board needs to be re seated, as it may have worked loose. I would open the phone and check that the screen is attached securely to the board.
Posted on Mar 29, 2008
Ive dropped my phone multiple times and it's always been fine, but last night i dropped it and the screen is white. is there anything i can do without having to pay for a new phone and/or damages?
chech if the contact to the display has been cut. This you can confirm by noticing whether the display atleast lights up any way. if it does not there may be a disconnection between power supply to your display. Also check of cracks on the screen. if there are cracks you may have to change the screen. I HOPE THIS HELPS YOU
Jul 18, 2011 | Samsung Cell Phones
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
My Nokia N70M goes Blank, LCD is lit, but cant see anything!
u have a display problem ur display needs to be changed
Sep 01, 2009 | Nokia N70 Cellular Phone
DELL Inspiron 5150 isnt booting
If it doesn't respond at all with no ram or hdd, it is likely that the board is in fact dead.....sorry. When you say you found a broken pin, I assume you mean one of the contacts from the power jack to the main board had a cracked solder joint and you resoldered it. If this is the case, try disconnecting and reconnecting the connector from the lcd panel to the mainboard. It may just not be making contact. Also, if you boot up with the hd installed, do you see the hd activity led flashing like at a normal boot? If not, sounds like a dead board. Try pulling the optical drive too if you haven't already. Try connecting to an external monitor too.
Hope this helps!
Aug 17, 2009 | Dell Inspiron 5150 Notebook
Black line across screen nokia n95 8gb
Completely switch off and remove the battery and again switch on.........If it not works then there may bea display problem and you need to change the display.
rate this if it is useful.
Feb 06, 2009 | Nokia N95 Cellular Phone
No signal and no picture, is it dead?
iS A LCD FLAT SCREEN EASY TO FIX. THE LIGHT FOR THE START BUTTOM LIGHTS AND THEN THE SCREEN IS BLACK
May 13, 2008 | BenQ FP757-12 17" Flat Panel LCD Monitor
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
Mar 17, 2008 | Nikon Coolpix 4300 Digital Camera
Screen problems
you have to remove the back of the phone with a small tri screw driver. underneath the board in a corner there is a flat cable that connects the screens to the board. It came loose. press the flat cabe back into the the board chip. they will lock together. the screens will work.. I just did this with my sons phone.
Jan 03, 2008 | Kyocera Switchback KX21 Cellular Phone
I was taking a picture on my phone and the screen went white
I had the same problem, but ive just turned it on and of and it goes away.
Aug 17, 2007 | Samsung SGH-D800 Cellular Phone
Frozen Phone...
try to reformat your sd card...
Apr 01, 2007 | Motorola Mobility RAZR V3
Nokia N95 Cellular Phone Logo
69 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
