Question about Frigidaire Gallery GLHS38EE Side by Side Refrigerator
Water in bottom of freezer
Saw red glow in back of freezer
    Problem Solver:
  • 4 Answers
The red glow you see is simply the defrost heater doing its job. When the refrigerator defrost control senses it is time to defrost the evaporator, it turns on a heater that in the dark, can glow brightly. This is perfectly normal.
Posted on May 12, 2010
Water dripping into fridge from freezer. noticed red hot element in back of freezer behind vent inside freezer
Heater glow behind frz back wall is normal during auto defrost cycle. This happens about 2 or 3 times a day for approximately 30 to 45 minutes. The water migrating into the fresh food section could be from a blocked drain tube which should be be in the area directly under the red glow you noticed. Should be a hole going through the floor into the drain pan under the refrigerator. Force hot water down hole until it flows freely.
Apr 07, 2015 | Refrigerators
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
There is a red glow from coil at bottom back of freezer that I can see through slats from inside. There is a sizzling water drip happening.
there is an element in there for self-defrosting, if you have a self-defrosting model. It heats up like an oven element ( not nearly as hot) to get rid of frost build up.
Nov 09, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerator/freezer not cold as they should be
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main
control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger
wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3
. Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1
end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min ,
look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red
glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a
shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat (
pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to
remove the inside rear wall of the freezer . The heater , is at the bottom of the coils ,
held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire
going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control
board , the temp of the coils , if they need defrosted , when they are thru defrosting .
This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the
coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to
also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front
of the drain , also with 2 white wires going to it , slid into a housing . This thermistor ,
is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off .
May 07, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
We have a TFX25JR side-by-side with ice maker and water dispenser; had water leaking on floor on freezer side of bottom left corner. Comes under tray, cleaned the coils and seemed to work, but 2 weeks...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Element at back and bottom of freezer has one bar glowing red with creaking/dripping sound sound
the unit is just in the defrost cycle. the red glow is the defrost element. the sounds you hear is it defrosting and the water hitting the element. it does this every 12-18 hours. shane
Sep 10, 2009 | Amana Refrigerators
I have GE side by side fridge. The freezer built up frost and then started to defrost. I took everything out andoened the back panel. The freezer was getting cold again but frost on the coils. the fridge...
Pull refrig out from the wall and unplug . Remove the 8" x 10 " panel covering the main control board . On this board , unplug the blue plug with 3 larger wires going to it . The sequence looks like this : wire1,wire2,space,wire3 . Use a piece of wire , with both ends stripped about 1/4 " , and insert an end into wire2 and wire3 . Plug refrig back in . Look inside the freezer at the back bottom , and see if you see a red glow . It may take about 30 seconds for the glow to appear . If no glow appears , the defrost heater located at the bottom of the coils ( glass tube ) is probably shorted . Pt # WR51X10042 . Also replace the defrost thermostat Pt # WR50X10068 . To access these parts , the inside freezer panel has to be removed . If you do get a red glow , then the main control board is bad Pt # WR55X10656 .
Sep 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Frigidaire Gallery GLHS38EE Side by Side Refrigerator Logo
164 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
