Question about ViewSonic VX924 19" LCD Monitor
My ViewSonic VA712b monitor blacks out for a second or two and then works normal. It may happen `5x/HOUR. It may be stuck in analog but I tried both analog and digital and it does it in both. A little blue square comes up and says analog. Any ideas?
  • 11,361 Answers
It may be indicating that the power supply may be failing. You may want to look inside for bad caps in the power supply section.
I believe this is same chassis as VA921B: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA912B/
Please look through my albums to see failed monitors due to bad caps.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 13, 2010
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Flat Panel LCD Monitor goes dark for 2 sec then back on
sounds like the backlite bulb is failing. best thing to do is to take it in and have it checked if is worth the cost. some can be replaced, some cant.
Jun 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Viewsonic VA712b lost Power Supply need voltage & current
davsmith00, Did you look on rear of VA712B where the power plug enters the power JACK connector? Maybe it will only tell you who is positive and who is negative (gnd) some monitors state what is the required V & I for them on the rear labels somewhere. This will teach you not to lose your supply. Did the dog hide it under the bed? Good luck finding a replacement. There are sources on web that specialize in drop-in replacement IN-LINE switch-mode-power-supply Bricks. You can also try newark.com and mouser.com and digikey.com to see if they have something. I'm louie12fix on fixya or lmistyrel@ aim.com Bye for now.
May 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VX2235wm LCD Monitor
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Sep 08, 2007 | ViewSonic VX2235wm LCD Monitor
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VX924 19" LCD Monitor Logo
333 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
