Question about Brown Stove Works TM210-3 Gas Kitchen Range
No Clicking Sound
When I turn on the stove, the gas does not turn on. I need to turn on a match and place it next to the burner to light the gas. The stove does not click anymore to automatically turn on the gas.
    Problem Solver:
  • 4 Answers
Sounds like the ignitor control module is bad, if none of the ignitors are working. If it is only one burner with a problem, it is likely an ignitor.
Posted on May 12, 2010
Testimonial: "Thanks. I will keep you posted."
Gas stove cooktop electric pilot light keeps clicking and wont shut offf
sounds like you have it handled...
Easy?
just a phone call away... this time , when he fixes it , watch what he does... so you can fix it next time.
Mar 24, 2013 | Tappan Kitchen Ranges
Burners won't light
That clicking is the igniter trying to spark. Turn on the burner and attempt to light it with a match. If you know gas is comming out, you will most likely have to replace igniter.
Sep 26, 2012 | GE WB13T10045 Gas RanOven Igniter Glowbar...
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Gas stove makes clicking noise when turning on
When a gas stove is clicking, it means it is trying to ignite the burner. If the knob is held in the ignite position for more then 3 seconds and the burner does not ignite, it means that (1) the gas is shut off to the stove, (2) she does not have gas service set-up yet at the apartment, or (3) the gas nozzles feeding the burner are dirty and clogged.
Most of the time, when you move to a new apartment, you need to call the gas company and have the gas turned on, unless it is included in your rent. Either way, when a house or apartment is unoccupied, the gas is turned off for safety reasons. I would contact the landlord to be sure.
Mar 22, 2009 | Stoves 600SiDOm Gas Kitchen Range
Gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Mar 01, 2009 | Stoves Kitchen Ranges
Gas burners/electronic ignition
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
I have a used kenmore propane gas stove that i just bought from someone. We have hooked it up but can only get the oven to come on. The stove top burners will not come on. We we turn on the burners we do...
In the old days stoves were lit with a match. If this does not work for you it would be due to the stove's lines remaining "airlogged" after the move. The oven purged and ignited more easily because it has a much larger orifice, so the air bled more quickly. I expect if you were to leave one burner turned on long enough for the air to bleed out you will find it to ignite normally. Do not leave the stove to bleed unattended, and if you encounter a strong smell of the gas, turn off the burner, and ventilate the room as needed. The smell of gas would indicate that gas is present, it may be possible that a lead came disconnected from the ignition module in the back of the stove. Again if this is the case, the ol' match will light the burner. Be Careful!
Dec 14, 2008 | Garland H283 Gas Kitchen Range
Brown Stove Works TM210-3 Gas Kitchen Range Logo
181 people viewed this question
Top Brown Stove Works Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Brown Stove Works Kitchen Range Expert? Answer questions, earn points and help others
