Question about Toshiba Satellite L500 Series Notebook
I was given an L500. It powers but fails to POST, this happened after a recommended BIOS update. Any kind of debug ports or something to sort this out?
  • 583 Answers
After a BIOS update, if it fails to post, the BIOS update got corrupted. This happens (rarely) and when it does, the only thing that can be done is to remove the BIOS chip and have it burned at a local repair shop (or sent into Toshiba for a replacement). Without the BIOS functioning properly, the computer can do nothing at all. If your BIOS is not on a removable chip, then the computer will have to be sent to Toshiba to have the BIOS replaced.
Posted on May 12, 2010
Why will my computer not start anymore?
Hard to diagnose without the machine in front of me. You say you updated this computer with the latest updates...was there by chance a Bios update in the mix? This behavior can be sparked by a failed bios update/successful update with a bad file/turned off mid update.
If there is more than one memory module, try removing them one at a time and testing that way...that will help eliminate ram as a suspect.
My expectation is that your motherboard is shot...either by a failed BIOS update or just unlucky timing of it happening following whatever updates were ran. Once you've eliminated power supply and RAM, its the most likely culprit. Unless you were heavily over clocking CPU's don't generally fail that catastrophically. Hope that helps and Good luck!
May 10, 2014 | Chieftec (DA-01WD) ATX Full Tower Case
Power on but nothing is diplayed on toshiba l500
If you still get lights on the edge of the laptop & you can hear the fan spinning and harddisk clicking a bit but nothing at all is appearing on the display then it's either the screen or the power inverter that have gone. Either way it's not really something you can do yourself, take it to a technician to sort out. If you are not getting any lights, fan or clicking sound then it is a power issue - the LED doesn't necessarily mean that the power supply is ok. Again, not much you can do yourself, take it to an expert.
there is another way as well for running the machine again, and for that you have to do this. First, unplug it from the power cord and then take the battery out, as you complete with this press the power button for few times, for example you can even hold it for 30 seconds or so, then see if it fires up.
Sometimes that helps flush out any little bits of electricity/static that may have built up. And the after sometime try to boot the machine and see what happens.
Together with this, you may would like to remove the memory panel at the base and take out the BIOS battery to reset the bios, then place it back in. If your BIOS is someway despoiled this will get rid of the difficulty.
May 06, 2012 | Toshiba Satellite L500 Series Notebook
Hi, I have a Dell Inspiron Mini 1011 Notebook The actual fault with it is that when you turn it on it error bleeps. This happened when a BIOS update failed. It was fully working before the failed BIOS...
If you're not getting any kind of video output then it's safe to say that your system board will need to be replaced (that's where the BIOS chip resides). If you are seeing something on your screen like "Hit F12 for one time boot options" then you might be able to salvage things by downloading from Dell the correct BIOS upgrade and putting it on a bootable thumbdrive.
Jul 13, 2011 | Dell Inspiron Mini 10 Notebook
While updating bios for toshiba satellite L500 un plug the electricity switch laptop stop responding any thing. now how to install bios again
Well, sorry to hear about that. It is usually advised to keep the ac adapter plugged in for continouos power supply while performing BIOS update. Reason beyond is that, sudden power interruption or power shortage can totally damage your computer, allowing you not to use your computer anymore.
Please contact your laptop manufacturer for further assistance.
May 06, 2011 | Computers & Internet
How do i repair the cmos for satellite l500? Bios update failed
To reset the BIOS read the information from this link. Although article is about removing BIOS password the second, third and fourth methods pretty much will bring the BIOS to initial factory settings.
I would suggest getting Hiren's Boot CD and use Kill CMOS to wipe the BIOS to the factory settings.
Feb 10, 2011 | Toshiba Satellite L500 Series Notebook
My toshiba satellite L500-1XC working fine but the fun is too noisy. any one have any suggestions? thanks for your time.
Try some of the following:
1. Download the latest BIOS updates. If still noisy: 2. Take it a service repair center for a fan and complete cleaning (it worked for me).
Until then, use a lower setting power plan to avoid being irritated :)
Thank you
Jan 22, 2011 | Computers & Internet
M laptop is toshiba L500.i was updating the bios
if it is in warranty go to the service centre otherwise it must be bios replaced by prof.
Jun 25, 2010 | Toshiba Satellite L500 Series Notebook
I turn my Acer on and nothing happens. The light
Try this it worked for me
Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
  1. Go here and download the latest BIOS for the netbook.
  2. Extract the files from the downloaded zipped BIOS file.
  3. In the Dos_Flash folder, rename the BIOS file from 3310.fd to ZG5IA32.FD, in all capital letters.
  4. Copy ZG5IA32.FD and Flashit.exe to the USB flash drive
  5. Ensure that the AC adapter is plugged in.
  6. Insert the USB flash drive into a USB port.
  7. Press and Hold down the Fn and the Esc keys together and press the power button.
  8. When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
  9. After the keys have been released the power light will start to blink.
  10. During the BIOS update process the display will be blank.
  11. Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
Note: These instructions are only for the Acer Aspire One AOA-110 and the AOA-150 netbook series and should not be performed on any other model Acer Aspire One.
Mar 27, 2010 | Acer Aspire One PC Notebook
Acer Debug went blank screen as if dead.
clear the bios by replacing the small battery on the mainboard.
Jul 31, 2009 | Acer Aspire 4315 Notebook
EliteGroup ECS AMD690GM-M2
get a debug card, put in the pci slot, put the processor, memory, hdd keyb, mouse on the place, double check it..turn on the power , read the last post code that display...watch for the blink of the 3 keyb lamp during power on...if there is no blink..then your o/b vga not initialized by the bios and (maybe) reading the other exp slot.
if there is a blink then check your monitor and cabling..record the last post code that display on the debug card (POST code display card), shutdown then remove all your device except for processor,ram,debug card , vga(if any external)...turn on the power again..did the post code is different or its the same with the last time?
shutdown,remove the ram, and vga (if any ext vga)..power up again (with only debug card and proc) did the code display the same or no ?
remove the proc and still with the debug card inserted in the slot..power up...what in the display?same?
you should be able to diagnose that..may be the proc (code 00 C0 C1 C2 ), may be the ram...maybe your o/b vga was dead..maybe your bios rom was still have bug (ECS ??=>does have a 2-3 years waranty..am i right?)
UDIN (indonesia)
Jun 13, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
Toshiba Satellite L500 Series Notebook Logo
293 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
