Question about MSI K7N2G-L Motherboard
Fastest CPU available for the K7N2G?
I own the nforce2 K7N2G mobo (about 4-5 years ago) and have the AMD Athlon XP 2600+. I'm looking into getting the fastest possible CPU for it, as the last "umph" for my system before my next major upgrade. Mine is MSI, and on the website it says:
CPU • Supports Socket A for AMD® Athlon(tm)/Athlon(tm) XP/Duron(tm) processors @FSB 200/266/333 • Supports 600MHz up to Athlon(tm) XP 2700+ processor or higher
http://www.msicomputer.com/product/p_spec.asp?model=K7N2G-ILSR&class=mb
What does it mean when they say "2700+ processor OR HIGHER"? How can TRULY determine what's the fastest supported-CPU is?
Thanks for your help!
Best,
Anthony
  • 3 more comments
  • MachEagle Mar 29, 2008
    Thanks for the prompt response TampaNative!
    I agree with your suggestion at upgrading my mobo as well. I do want to ask for further advice on that, but first here are my current specs:
    *nforce2 K7N2G mobo
    *AMD Athlon XP 2600+
    *1GB DDR ram
    *XFX Geforce 7600GT 256MB (AGP card, mobo has no PCI-E)
    *350W power supply... :(
    For a temporary upgrade (that I hope can last me for at least 1 more year), my budget is around $300. Is that enough? If so, what are your suggestions as to which mobo and CPU I should get? After the nforce2 series, I've not been up-to-date on any of the newer generation mobos.. would appreciate any suggestions (like should I go for nforce3, 4, etc. and would they be compatible with my ram?)
    Thanks again in advance for your help.
    Best,
    Anthony
    Like for example, would getting something like this be good?
    http://www.tigerdirect.com/applications/...
    Wait, that link was somehow broken, try this:
    3rd try...
    Ok 4th try.. just paste "=3559703" after the link
    President:
  • 778 Answers
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Posted on Mar 29, 2008
  • Frank  Fernandez
    Frank Fernandez Mar 31, 2008
    Anthony,
    Sorry but I couldn't get anything out of the link even after adding the "=3559703", but don't give up, if you keep trying so will I.
    With a $300.00 budget you should be able to upgrade your tower to be Quick enough for years to come, it just depends what kind of activities you will be tasking it with? You will do well to just shop around and look for bundles/package deals. Don't skimp on cooling (Processor heat sync & fan, case fans, etc...), and get a good power supply too. Again $300.00 should be more than enough but don't forget RAM as your current DDR RAM probably won't be compatible with any new MoBs you may find. So to recap: MoBo, Processor W/heat sync, Power Supply, Fans and RAM. You may even be able to get a new case including Power supply and fans, if you take your time and catch some good Sales while remaining within your budget.
    But, if it's only for one year? Keep it to just what you need and is compatible with the DDR RAM that you already have, as Memory isn't cheap. If you take this route, you should be able to stay way under budget.
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
My motherboard has fried: Albatron KM18G Pro 2003. It no longer seems to be available. For the computer to be exactly as it was before disaster struck, do I need exactly the same motherboard?
Well you do not need exactly the same motherboard. You need a motherboard that has the exact CPU socket, DDR slots and AGP or PCI slot.
Here are the specifications for the motherboard: Processor
- AMD Athlon/Athlon XP/AthlonXP Barton/Duron Processor
- FSB 200/266/333MHz
Chipset
- North Bridge: NVIDIA nForce2 IGP
- South Bridge: NVIDIA nForce2 MCP
- I / O Chip : Winbond W83627HF
Memory
- 3 DDR Sockets:
DDR200 to 400 non-ECC DDR SDRAM up to 3GB (Single Channel) or up to 2GB (Dual Channel)
Expansion Slots
- 1 x AGP 8X/4X slot (1.5V Only)
- 3 x PCI slots (PCI 2.2 compliant)
IDE Connectors 2 ATA133 channels (up to 4 ATA 133 IDE Devices)
Onboard I/O Connectors
- 1x Floppy Connector
- 2x USB 2.0/1.1 header (4 ports USB cable optional)
- 1x CD_IN header
- 1x COM Port header
- 1x S/PDIF in/out header (S/PDIF in/out cable optional)
- 1x CPU fan header with fan rotation detection function
- 1x System fan headers with fan rotation detection function
- 2x 5 pin system panel header (Intel spec)
- 1x 3 pin Power LED header
- 1x 4 pin Speaker header
- 1x Front audio header (Intel spec)
- 1x Case Open detection header
- 1x Wake on LAN
- 1x 4 pin TV-Out header
So you have to buy a motherboard that has Socket A, that support DDR I memories and has an AGP slot (for the video card).
If you need further assistance, just leave a comment. Thank you for using FixYa.
Apr 19, 2010 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
Amd athlon xp 2400+ problems witha epox ep-8kra2+ motherboard?
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
Feb 14, 2010 | EPoX EP-8KRA2+ Motherboard
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
How fast of an amd athlon processor can i use in a biostar m7mkb?
According to these specs 500 Mhz and up
http://www.motherboard.cz/mb/biostar/M7MKB.htm
Your motherboard supports a slot A Athlon.
The fastest looks like up to 1Ghz as according to CPU World:
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20(Slot%20A).html
Hope this info answers your questions. Feel free to comment if you need further info from me.
Rate me please when you get the chance.
Mar 04, 2009 | Biostar Slot A M7MKB Motherboard
K133ASA via Apollo motherboard cpu upgrde
Socket A/462 can take any AMD K7 family processor. The fastest you could get would be the Athlon XP 3200 I believe, but that could also include the Athlon 1400 and the Duron 1800. So it looks like you can make a significant upgrade of yhe processor.
Jan 28, 2009 | Computers & Internet
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
Oct 13, 2008 | Intel Motherboard
Cpu install
If you go in to the bios you should be able to change the multyplier from x6 to x16.
Failing that try loading optimized default in the bios. :)
Dec 20, 2007 | Intel Motherboard
MSI K7N2G-L Motherboard Logo
282 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
