Question about Samsung LN-T4071F 40 in. LCD HDTV
Samsung's lnt 4071 is slow to turn on after the lcd has been off for a period of time. I hear clicking sounds (58 times) before the set will turn on. What do? I have read on blogs something about a "cold start up problem"
  • 87 Answers
Great tv, I own the 46". Call Samsung they will fix for FREE
Posted on May 12, 2010
JVC LT-42E910 LED flat screen TV, backlight comes on, menu box is displayed but after about 5 seconds backlight goes out. Picture and sound still working but no backlight. How can I troubleshoot?
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Jan 11, 2016 | JVC Televison & Video
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
Hi where is the t.con board located in samsung LNT 5265 tv
Usually it is the small board at the top middle of your set, most time it is behind a medal plate with 4 screws. There will be 2 or 4 flat ribbon cables connected to it. Hope this helps!
Dec 13, 2010 | Samsung LNT5265F 52 in. LCD HDTV
My samsung lnt 4071 will stall when turned on. If the tv has not been on and warm and I turn it on while cold, i t takes about 3minutes to start. I hear a click sound.
Take ur tv aparts,the power supply board it where u plug in the a/c power cord in it.U know basic electronic and soldering?Ur tv power supply board have dead parts it call capacitors,these capacitors they bulges up on it top or puff up on it top.Replaced these dead gases leakages capacitors.Ur power will turn on normal cold or hot.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power suppply board for the replacement.
May 12, 2010 | Samsung LN-T4071F 40 in. LCD HDTV
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
I have a samsung LNT that turns on only after clicking for about a hour,
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Nov 26, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Honeywell Digital Thermostat won't click on if temp is below 59
do you live there? if so here are the rules for setting back temperature: do not lower the temperature more than 8 degrees F from the temperature you want it when your there, setting it back for periods of less than eight hours is also somewhat futile. Due to laws of thermo-dynamics the heat required to recover from more extreme setbacks or shorter periods of time exceeds the savings acquired by taking said action. As to your question directly there are no reasons why your thermostat should not function at any setpoint temperature that it is allowed to set to (45 normally being the lowest) if it does not function below 58 degrees it has a failure and should be replaced before it fails completely. Suggest a Robertshaw or Braeburn brand thermostat, Honeywell quality has slipped over the past decade to unacceptable levels. Unless your considering a Hunter in which case buy another Honeywell.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Rainbow of vertical lines during startup
I could be a tuner problem. But since the set is new, you should return it for replacement.
Geno
Feb 27, 2008 | Samsung LN-T4671F 46 in. LCD Television
Samsung LN-T4071F 40 in. LCD HDTV Logo
688 people viewed this question
Henry  Thomas
Henry Thomas
