Question about Dewalt 2 Hp 4 GAL Air Compressor
Hi were can I buy a spray gun for dewalt compressor
  • 2,984 Answers
Anywhere, really....Sears, Home Depot, Lowe's, Harbor Freight, just about anywhere....even WalMart.
Posted on May 12, 2010
My Dewalt D51825 leaks air from the piston rod. Bumper seems to be okay Can any one help?
Air leaking from nose of gun indicates air getting past bulkhead orings. Bulkhead is white plastic frame inside of gun. Replace gold colored vinyl orings with like size buna orings. Remove cylinder from bulkhead to find two bad orings. Also replace trigger valve or vinyl orings within valve including the two orings on the firing pin. Good luck.
Feb 01, 2017 | Dewalt Air Tools & Compressors
How Do You Choose an Air Compressor for Home use?
you go by how loud it is
2 HP is a std home use direct drive motor 240 volt
with regulator
.. pump tyres . air hose .blow of benches low pressure spray paint gun a rattle gun
step up to twin cylinder belt driven compressors
trade preferred
for high daily use of air tools and spray painting..
8cmf to 10 cmf and more
can high pressure gravity feed spray gun
Oct 21, 2016 | Air Tools & Compressors
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
Feb 09, 2011 | Dewalt DC616 16g Cordless 18v Straight...
The bit in my Dewalt 6.3 Amp Dry Wall Screw gun will not pull out, how do I get it out to change it and how can I change from a Phillips to a nut driver tip.
The bits are held by a spring snap ring that sometimes takes a lot of force to release.
Spray a little bit of CRC226 into the bit/chuck interface and grab the bit with a set of visegrips and PULL !!!
The CRC226 is available in a blue spray can at Home Depot in the electrical dept and fights rust. A can is about $2.70... make sure to get the 226 as there are other CRC products there.
Jun 27, 2010 | Dewalt 6.3 Amp Dry Wall Screwdriver
I am having problem with my Dewalt D51823 Framing Nailer- air started leaking out of the nose always when is plug to the compressor. the gun is immaculate inside. quite annoying the compressor keep...
Either the plunger has not completely returned to the "pre-firing" position, or there is a defect in one of the o-ring seals. Make sure that the gun is sufficiently lubricated and if so, then next check the condition of the o-rings. An improper seal will cause this. It is also possible that the trigger assembly has a small crack/leak.
Dan
Jun 11, 2010 | Dewalt Heavy - Duty 31° Clipped Head...
My dewalt heavy duty coil roofing nailer seems to misfire when shooting nails. The nails it shoots they come out slow, then it misses a bunch of them. I think the plunger is stuck. How do I get this...
before tearing apart spray gun plunger and shaft with carb cleaner than spray with a spray lube like wd40 sometimes the plunger gets debris on it if still misfiring call dewalts 800 number they can advise of local repair shop and also advise if problem can be fixed by u
Jan 23, 2010 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Sounds like a loud leaf blower, no engine sound.
You can get a rebuild kit from DeWalt for about $40 and fix it yourself. The flappers are most likely bent.
Jul 21, 2009 | Dewalt d55151 factory reconditioned emglo...
Spray gun for water and air
You can buy them here for about $22 US.:
http://www.detailyourcar.com/airwater-guns-and-hose-c-51.html
They're used for detailing cars, if you don't like these, Google "air water guns"
Jan 19, 2009 | Air Tools & Compressors
Dewalt Glue Gun Warming Problem
Are you in the UK? The fuse in the plug might need replacing. I had the same problem with glue guns. It's not worth buying an expansive one. The cheap ones might take a bit longer to heat up but the last just as long if not longer. I can never tell when the element will go.
Aug 27, 2008 | Dewalt 18V Cordless Adhesive Dispenser...
Dewalt 2 Hp 4 GAL Air Compressor Logo
66 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
