Question about Hotpoint FFA90 Bottom Freezer Refrigerator
Interior light The original bulb blew so I purchased a replacement put it in and it lit for about 10 seconds and blew. I then got another one put it in but it will not light up but hasn't blown. Any ideas would be welcome. Thank you ****
  • Jackosnr Apr 01, 2008
    Thanks Mack for your suggestion but it's not that, tried new bulb but no joy.
    Have metered the socket and the door switch no voltage. The wires from the the light got to the main PCB but unable to check from there on. ??
    Scholar:
  • 27 Answers
Hi. I've seen this situation on this model. The bulb is not screwed in all the way. You think it is but it is not. If it still doesn't work, get new bulb. Sounds like you got a couple bad bulbs. Good Luck, Mack
Posted on Mar 29, 2008
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
2006 Tocson V6 Limited. Dome/Interior lights
you either blew a fuse or you blew the light bulb
Nov 23, 2009 | 2006 Hyundai Tucson
Window, interior lights, car alarm and fuse keep on burning out
you have a short circuit or burned out wires somewhere, could be anywhere.
Try disconnecting the alarm, taking the bulb out of the interior lights, and putting in the fuse, if it blows again you know that the alarm or interior lights are not at fault, if it stays good replace the bulb and if it blows theres your faulty circuit, if it stays good then the windows are at fault.
Oct 09, 2009 | 2000 Volkswagen Jetta TDI
Boxlight CD-725C TEMP light comes on and unit shuts down afer 10 minutes. Unit has about 1200 hours on the bulb. Seconds before the unit stops, at least one of the fans slows down.
The reason why the temp comes on because the fan is start slow down, so the bulb produce a lot of heat. Once the maximum temp reach, the temperature sensor will become inactive. So boxlight shutdown. First you need to replace the fan, or check the supply dc voltage going to fan if it is stable.
Jul 24, 2009 | Office Equipment & Supplies
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
87 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
