Question about Samsung RFG237AARS Bottom Freezer French Door Refrigerator
Samsung Bottom Freezer Won't Pull all the Way Out
We have a samsung Rfg237aars with french doors. The freezer is not pulling out all of the way. It use to pull out an additional 2-3 inches, but now stops. It is also all frosted over. It is only 1 month old.
ngfam1
  • 639 Answers
SOURCE: Samsung frost free fridge freezer - RL39WBSW
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
  • 163 Answers
SOURCE: I have a new Samsung RFG297AA fridge and I am
this could be that your gaket may be sucking in air.check gasket dollar bill trick.put dollar half way in freezer and pull it out.if it pulls out easy your gasket isnt sealing.be sure to go all around the freezer gasket with the bill.
Posted on Mar 06, 2009
  • 9 Answers
SOURCE: I'm getting frost in freezer of my Samsung french
i would check the magnetic seal around the door to make sure it is not letting air in ...this is the cause of the over freezing.
Posted on Jul 13, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: my refrigerator both the freezer and fridge
have your technician check your thermostat control first, see if there is some faulty circuit on it, if non then your motor compressor, there might be some mechanical failure inside your motor compressor
Posted on Nov 13, 2009
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Setting time display
Go to google type the model number and get the owners manual. I could tell you but you would learn more by doing it yourself
Apr 02, 2014 | Samsung RFG237AARS Bottom Freezer French...
How to level
Usual is by front feet, turn them up or down. I tend to have the unit lie back slightly, gives a better door seal. only6 by a couple of degrees, but does help. IF not enough adjustment from feet, I use plastic blocks to raise it up at whichever corner or side needs it
Mar 05, 2013 | Samsung RFG237AARS Bottom Freezer French...
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
Samsung rf217acrs frost in freezer
I have the same samsung with the same problem. I had a repair company come out. What is happening is you are not opening the freezer door correctly and not pulling the tray out all the way. It is a design problem with the door. You must pull it out from the center of the bar and pull it out all the way for it to align correctly and then the door will close correctly. I was getting frost on the right side roller and top area if I don't do it correctly. There is nothing that can be done I am told. You must not pull from the side of the handle. It works fine now. Try this and see if it helps.
Jun 19, 2012 | Samsung RF217ACRS Bottom Freezer French...
I have a new Samsung RFG297AA fridge and I am noticing a little frost on the outside of the pull out drawer in the freezer. What do I need to do?
Mar 06, 2009 | Samsung RF265AA Bottom Freezer French Door...
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
Dec 21, 2007 | Samsung RF265AA Bottom Freezer French Door...
Samsung RFG237AARS Bottom Freezer French Door Refrigerator Logo
296 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
