Please help my washer works fine until it gets to the spin cycle. the washer empties the water then starts to fill up again even though it is spinning. the washer continues to pour water until the spin cycle is over.
  • 4,070 Answers
Some washers start the refill near the end of the spin so excess soap can be rinsed off before the rinse and the water is drained and continues to run when the spin stops. If this is not normal for your washer then your cycle selector is worn and will have to be replaced.
Posted on May 12, 2010
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
My washing machine keeps getting water in it after the cycle is over. This morning I came in and my empty washer was filled with water and had overflowed onto the floor. Help! There are also times when...
mine also remains wet and soggy, even after the spin cycle. However, I have not, as of yet, (and hopefully won't) begin having overflow problems.
Mine is jumping around the laundry room - as though in an unbalanced cycle. We discovered that one of the "feet" that the washer stands on needs to be adjusted, upward or down, so that the washer stands balanced and evenly. The "foot" does not make contact, and when we turn it to change its height, it just goes in circles without changing height.
Mar 09, 2010 | Whirlpool Washing Machines
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
