Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Control light saays on and washer will not start. I did 2 loads earlier today without insodent.
    President:
  • Whirlpool Master
  • 662 Answers
Http://www.fixya.com/support/t5006688-control_panel_red_light_control_locked
Posted on Jun 02, 2010
HE2 Plus Washer starts then shuts off immediately.
Aren't microprocessor controlled appliances wonderful? Especially when the code is flawed! No wonder the space program bit the dust!
May 12, 2017 | Kenmore HE2 Plus Front Load Washer
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
Unit will not power up. No lights, nothing. Acts as if there is no power at the plug, but I have verified there is power. Unit was working earlier today. Finished last cycle, didn't know anything was...
we had the same **** issue with the lg washer. we fought with the company as it was only 1 year old. do you know they asked us if it was plugged in hello my husband is an electrician. they came out it needed all new brains. to bad i cant give you the brains because now the piece of **** wont finish a wash even when empty reads ue. its going out on the sidewalk for any ****** who wants to pay to fix it .
Mar 13, 2010 | LG WM-2277HW Front Load Washer
The washer was working great earlier today...went to change laundry and had an error message on the screen..it was like F33..stopped spinning and draining..used shopvac to clean out hose and tried...
Hi
Thanks for using FixYa. Error F33 means PUMP DRIVE SYSTEM ERROR. When the connection between pump and the Central Control Unit (CCU) is lost, F33 error comes on the display.
Possible Causes/Procedure—
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Plug in washer or reconnect power.
4. Verify CCU operation by running a Diagnostic Test or any cycle.
Motor Continuity Test—
2. Disconnect the wire harness from the motor and measure the resistance of the motor. Use the following table:
Pins Results-
1 to 2, 2 to 3, 1 to 3 Normal if value between pair of pins = approx. 6 ω & Abnormal = Infinity.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Just had an Affinity front loading washer delivered today. Did four loads without any issues, clothes are clean and smell great. After the washer was idle for about an hour, it started beeping, and the...
try disconnecting the power for at least 30 seconds which might reset control if this fails call service the control is faulty you have a 1 year full warrenty
Dec 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Front Load Washer 417.44152400 lights up, no activity
Find the button on your panel with a 'key' symbol. Press & hold this down till the lock light goes off. Or
Hold down the 'options' & 'select' buttons together till the lock light goes off. Or
Press and hold down "end of cycle"
Pl. rate & tell me what did it - it is important.
May 23, 2008 | Kenmore 44102 Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
