Question about Rancilio Silvia Espresso Machine
Rancilio silvia espresso coffee machine
Hi
i need to get a new boiler/element for my machine.
Can you please tell me where can I purchase spare parts.
Esprosso Parts http://www.espressoparts.com/ sells all parts for the Rancilio Silvia, including some customized and modified parts.
Posted on Jan 18, 2009
SOURCE:
How do you reset the thermostats on the rancilio?
Safety thermostat for rancilio silvia is on the boiler and has a red button on top.Press this button down and you should be ok.
Other thermostats cannot be reset - just replaced.
If the boiler temperature exceeds 165 degrees Celsius, this thermostat will trip, cutting power off from the element. This is done to try to prevent element damage due to overheating.
Mar 25, 2014 | Rancilio Silvia Espresso Machine
I have a Rancilio Silvia Espresso machine and its tripping the circuit breaker in my kitchen, any advice as to what i can do to fix this problem
use a voltmeter and check if you have continuity across the element terminals,(do this with macine unplugged and terminals off element. this will happen if something has cauased the element to fail. or check if you have a leak on top of boiler that is shorting out aomething.
Sep 16, 2011 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
My Rancilio miss Silvia coffee machine is not heating water any more. Which part should be replaced? Thank you
Could be a switch, a themostat, a wire connection, or the boiler element. Someone with a volt-ohm meter will have to help you.
Once you figure it out, you can get the parts here
Rancilio Silvia Parts
Dec 09, 2009 | Rancilio Coffee Makers & Espresso Machines
Upon turning on the Rancilio Silvia, it trips the house breaker switches. Have moved to different outlets and does same thing. Had been working ok previously. Thanks.
Hi
Sorry to say but your boiler element is ruptured and needs to be replaced. You can do an ohms check across the element terminals and if its good you will get a reading of 12 to 16 ohms.
Oct 13, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Keeps tripping the Breaker
Usually when that happens there is a problem with the element in the boiler.
Jul 06, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia - Burning/smoking
From the pic I can see that the element is burnt out, you will have to replace the boiler(boiler and element come in one piece), check with your local Rancilio dealer or check with EspressoPartsNW, for a new boiler/element, also get the gasket for that. To remove boiler disconnect connection to pump and steamvalve, then remove allen wrench screws.
Mar 14, 2009 | Rancilio Silvia Espresso Machine
Rancilio silvia
Youve probably run your boiler dry and blown your thermostat/s. You'll need to have them replaced. You may get away with only having to replace one. It will cost about $80(AUS) to have done or less if you source the parts and do it yourself (not recommended).
Sep 08, 2007 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
969 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Ekse
Marvin
Marvin
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
