Question about Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case
How do I calibrate my Keypad to be more accurate?
    Problem Solver:
  • 13 Answers
To Calibrate The Touch Screen:
1. Turn off GPS
2. Hold Power Button for 30 secs or so
3. Calibration screen will appear
Posted on May 21, 2010
Oven will not reach temperature set
Get an accurate thermometer. Look on the oven control, there will be a calibration screw. It takes a while, but with small adjustments and accurate temp measurements, you can calibrate the control.
Nov 22, 2013 | Kenmore 30172 / 30174 / 30179 Gas Single...
Touch screen calibration
To calibrate the StreetPilot c-Series touchscreen, follow these steps: Begin with the device turned off and unplugged from a power source Power the device on and continue to hold the power button for 1 minute Release the power button when the screen displays "Press Dot" Accurately touch the dots as they appear The dots will change location A stylus or pencil eraser may be used to accurately touch the dots Touch OK when the "Calibration Complete" appears The touchscreen is now calibrated.
Oct 16, 2013 | Garmin StreetPilot C330 GPS Receiver
No communication from start stop buttons. cannot get into calibration mode
you must adjust the REED swith, see the diagram attached, clean, and tight the wires connector very well,
Tight the ribbon cable from keypad verywell, and tight the connector from display board vs lower board.Clean the keypad with special spray contacts.
After you fix it. RUN the s. calibration.
God bless you
May 22, 2012 | Nordic Track NordicTrack T5 zi Treadmill
Some letters on my htc wildfire keypad not working
Hy, Try to calibrate it in the keypad setting option
May 07, 2012 | HTC Wildfire
Numeric keypad is not working
Go to settings then click on phone then click on touch input then click on touch screen calibration then do the calibration for 3 to 4 times then check your numeric keypad
Jan 02, 2012 | Nokia 5230 Cell Phone
Need to know how to calibrate my honeywell RTH221
This thermostat is not field servicable,you cannot calibrate this thermostat.May want to consider moving it closer to return air of equipment, for more accurate sensing of building temperature. Why do you feel that it needs calibrated? Suggest setting another thermometer on top to verify its accuacy.
Nov 24, 2010 | Honeywell Heating & Cooling
How to calibrate
Calibrate or align? Align cartridge instructions are:
  1. Make sure the printer is loaded with unused white paper.
  2. Press the Setup button on the control panel, and then press 6 on the keypad or scroll to Tools .
  3. Press 4 on the keypad or scroll to Align Printer .
  4. Press Okay , then pressOK again when the alignment is done to continue.
Aug 28, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Have set screen lock to 1 minute, but when I have to use the keypad in the middle of a call (e.g. in response to instructions to press a number), the keypad locks up in 3 seconds or so. I have to...
ok this model of phone has a sensitive screen and will cause the screen to have a slight malfunction if it is repeatedly touched. you really want that screen locked as soon as it can. you can set the screen to wait a little long but i also have this model of phone and if your talking on it with the screen unlocked you will scramble the calibration on the screen. to repair the calibration you go to the four little dots hit it go to the settings wheel at the bottom right. ok now go to more . go to touch calibrations at go thru the calibration of the touch screen it may tell you that your off a few times but dont worry this is normal. continue thru the steps and save when you feel you have it set to your liking.
Nov 10, 2009 | LG Vu CU920 Cellular Phone
Difficulty texting with the CECT P168 mini cell phone
The keypad is fixed. You can try to recalibrate the screen to make it more accurate. Go settings->pen calibrate
Nov 29, 2008 | Dual Electronics CECT P168 Cellular Phone
Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case  Logo
529 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
