Question about KitchenAid KGST307 Gas Kitchen Range
Oven working but not heating past 50 degrees - KitchenAid KGST307 Gas Kitchen Range
  • 5 more comments
  • johannat100 Oct 18, 2008
    The control pad is showing the oven as heating up, but the oven never gets hot. It was working the day before. The stove works.
    Thanks
  • martyn748 Oct 21, 2008
    Same problem, it lights, burns fine, but will not build up any flames to heat properly
  • Anonymous Nov 07, 2008
    Same problem with me
  • peterj47 Nov 13, 2008
    I have a similar problem though it appears to be not consistent. Only occasionally slow to heat. When it is slow to heat there is a sometimes a slight gas smell and yet when I check the flame the oven burners are burning. Is there a chance that the gas pressure is not high enough? The ingniter seems to be doing its job correctly.
  • sarah545 Nov 22, 2008
    Same problem here. Oven does not heat past 325 and that takes 45 minutes!
  • Anonymous Dec 02, 2008
    I have the same problem - anyone know what is wrong?
  • greenback Dec 21, 2008
    Electric oven will only heat to 50 degree's or so. Please advise the best
    step by step. Unit is about 20 years old.
Posted on Oct 22, 2008
SOURCE:
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
Oven not heating properly - 25-50 degrees off - do I look at the heating element or what do I do?
if its off but heats fully i.e. 500 degrees then check for a defective thermocouple or oven temp control not an element
Oct 26, 2009 | Ovens
Oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Our oven is not heating up past 150 degrees. The
The element will have to be replaced if there is no power going to it.
Jul 20, 2009 | GE Spectra JBP84 Electric Kitchen Range
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Jan 02, 2008 | Ovens
KitchenAid KGST307 Gas Kitchen Range Logo
262 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
