Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My hd52525 just replaced heatlamp, plugged it in and turned it on. Lamp comes on for 5 seconds then it goes out. Then solid red lamp light comes on. What do I do?
    President:
  • Mitsubishi Master
  • 1,619 Answers
Cooling fans may still be clogged with dust including the ones connected to projector. Try removing back and cleaning them out. If that doesnt do it you may check boards for blown capacitors.
Posted on May 12, 2010
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Hey there! Just replaced the lamp in my sony KDF70xbr950 and now it will not even come on I have 4 flashing red lights and then goes back to a solid red light can some one help!! ...
The LAMP light is flashing or blinking.Solution
If the LAMP light is flashing, first attempt to perform a power reset on the television. If this does not resolve the issue, then the lamp inside the LCD projection television may have burned out and will need to be replaced. If this appears to be the case, consult the Replacement Lamp Part Number table to determine the correct replacement lamp for use with your projection television.
NOTE: The LAMP light is not the same as the POWER/STANDBY light.
How to perform a power reset on a Sony® television.Solution
Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.Unplug the television power cord from the electrical outlet. Let the television remain without power for 60 seconds.Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.Turn on the television.
Sep 16, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
Jun 10, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
No picture no sound will turn on but not off, red light comes on
When the red light is lit press both the menu and device buttons in on the front of the set in together and hold for 5 seconds then record the two digit blink code that will repeat. I am assuming you will receive a 34 error or a 41Error. But let me know what blink code you get and I will assist you.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
May 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY GRAND WEGA
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Oct 23, 2007 | NEC VT47 Multimedia Projector
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
