Question about Steam Fast SF-220 Hot & Hy Vacuum
ATTACHMENT i CANNOT REMOVE IT
Hi! I have a hand held, looks like a 228, blue color and it came with a lot of different attachments.
I added the larger surfaced attachment and now I cannot get it off! Please Help?
I have to twist and wiggle it in order to get mine off
Posted on Aug 01, 2010
How do I use the crevice attachment
Hi there! The crevice tool can only be used when using the unit has a hand vac. Remove the handle and nozzle from unit. Attach the crevice tool by inserting into hand vac nozzle opening. To remove, gently pull apart. Hope this helps!
Sep 30, 2014 | Dirt Devil SD20000RED Versa Power AllinOne...
Cannot find filter in bag compartment
If you're looking for the exhaust filter, it is on the top of the machine under the crevice tool and dusting brush.
If you look at the rear of the machine you will see a tab on the attachment holder.
Remove the attachments on the unit
Push tab on rear of vacuum on the attachment compartment
Lift cover and your exhaust filter should be exposed and should just pop right off for replacement.
Mar 03, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
No suction at floor section only on hand held part
clean the hoses and any part connecting the actual vacuume to the floor attachment.... probably clogged or not getting a good seal....if the motor sounds like its going faster (higher pitch) then its clogged up.....
Nov 09, 2013 | Russell Hobbs 14835 Tornado Stretch...
I disassembled the handle to attempt to remover the slip in upper half of handle. (did not figure out how to do tht). Now on re-assembling the handle, I cannot figure how the trigger is held secure to...
HI.These are the steps that may be helpful since you haven't describe the brand of your unit.Open the storage door at the front of the vacuum.Redmove the powered hand tool. Set it aside.Unsnap and remov any attachmets at the attachment storage area.Unclip and remove the wands from the vacuum and set aside.Pull the end of the hose from the hosed tube rack.Twist the other end of the hose from the dirt duck tube.Remove the hose.Unscrew the back of the handle.If you can't remove ,it is held tightly with nbuts located at the back of the compartment bag.Pull the handle carefully from the vacuum.If it has a non built cord wrap,slidethe wrap straight up from the handle too detach it before removing the handle.Once done assemble back.Thank you for choosing fiXYA.
Jul 31, 2011 | Vacuums
I'm trying to blow up a pool with my kirby. i forgotten how to use it. can you instruct me
The vacuum is designed to be an upright vacuum or a hand held canister vacuum, or a blower.
It comes with many attachments.
Please use the blower attachment.
Jul 04, 2011 | Kirby Ultimate G Bagged Upright Vacuum
When I try to disconnect the hose in order to use the hand held hose with an attachment, the dust from the bottom flies into the air. How does this opening get blocked off to ensure the dust enters...
It is a matter of Physics. It seems like you have it running when you change the hose. ?? That's a no-no.
Basically you will have o take it apart until you know how it works or wont work
Jan 29, 2011 | Bissell Vacuums
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
Steam Fast SF-220 Hot & Hy Vacuum Logo
51 people viewed this question
Top Steam Fast Vacuums Experts
Are you a Steam Fast Vacuum Expert? Answer questions, earn points and help others
