Question about Sharp 61RWP4H 61" Rear Projection Television
View timer only lights
PLUG IT IN,push power button,nothing happens.(no picture) red pwr led switches to view timer led and I can't turno or off tv. what do I do to clear and get back to cable picture?
  • 2 more comments
  • OFNER22 Apr 05, 2008
    TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
  • snmo2001 May 17, 2008
    Same as Above
  • boscowall May 11, 2010
    How do you remove the front panel?
  • jereem328 May 11, 2010
    cant turn tv on veiw timer light is on
Posted on Apr 05, 2008
  • OFNER22 Jul 18, 2008
    FOUND TAKE FRONT PLATE APART WHERE FRONT TV CONTROLS ARE AND CLEAN THE RESISTER TV IMMEDITLEY TURNED ON AND NO MORE FLASHING LIGHT.
    I FOUND THAT IF YOU TAKE APART THE FRONT COVER PLATE WHERE THE TV CONTROLS ARE AND CLEAN THE RESISITER THE TV TURNED RIGHT ON FOR ME.
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
There is no picture or sound
check your lamp, if lamp has been replaced then re-set the lamp timer, if you hear a clicking or buzzing and no picture is probable that you could have a ballast problem. I'd check the lamp first though.
Apr 13, 2010 | Toshiba 65H80 65" Rear Projection...
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
No picture, no pwr at color guns, no sound, pwr light on
Push in the menu and input buttons on the set and hold them in for 8 seconds together and see if the led blinks a two digit code, then let me know what happens.
Apr 05, 2008 | Mitsubishi VS-5059 50" Rear Projection...
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
Oct 05, 2007 | Sony KP-61V85 61" Rear Projection...
Sharp 61RWP4H 61" Rear Projection Television Logo
341 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
