Question about E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop
I Can't Find My (E) Drive I Have My Picture's & My Movie's In It,That Was Also My Back-Up It's a 1 km Hard -Drive That you connect to Your Pc Computer.
    President:
  • 3,278 Answers
Hello.
Go to the external drive manufacturer's website. Download and install the driver for your specific model and operating system.
Then, see if your computer sees the drive when you connect it.
If not, there could be a problem with the drive's USB cable or the drive itself.
Also, be certain that your computer's USB ports are OK.
Hope this helps.
Posted on May 12, 2010
How do I open the case and remove the hard drive?
Unplug the unit from electricity, wash & dry your hands, take steps to avoid you transmitting static electricity(look it up if you are not familiar). There are several sheet metal screws around the edge in the back of your CPU. Remove the ones that appear to join the outer lip to the inner lip all the way around. The front & back should now separate into 2 pieces. One the shell & the other the bulk of the system. The hard drive is usually located on a standard mounting shelf by itself with 1 or 2 small screws holding it in on the side with 2 wire connections in the back. The larger is a ribbon cable the is used for data & the other is the power cable. pull out the cables, unscrew the screws & the hard drive slides out. Some boxes may have something that blocks your access to screws, if so, temporarily remove them so you can work. If you are not sure of a potential problem...take a smart phone picture so you can see how it goes back together.
Jun 22, 2015 | Dell Dimension 3100 PC Desktop
What services does Kia Sportage 2008 with 90000 need?
Here is recommended maintenance up to 10 1/2 yrs. If you follow through list, you should be able to tell by elimination what you may need. Here is the link - also list pasted below, here:
http://www.kia-forums.com/2g-2006-2010-rio-rio5/35574-maintenance-schedule.html
SUGGESTED Maintenance Schedule:
Months Kilometres Maintenance Type
4 months 6 000 km Maintenance #1
8 months 16 000 km Maintenance #2
12 months 24 000 km Maintenance #1
16 months 32 000 km Maintenance #3
20 months 40 000 km Maintenance #1
24 months 48 000 km Maintenance #2
28 months 56 000 km Maintenance #1
32 months 64 000 km Maintenance #3
36 months 72 000 km Maintenance #1
40 months 80 000 km Maintenance #2
44 months 88 000 km Maintenance #1
48 months 96 000 km Maintenance #3
52 months 104 000 km Maintenance #1
56 months 112 000 km Maintenance #2
60 months 120 000 km Maintenance #1
64 months 128 000 km Maintenance #3
68 months 136 000 km Maintenance #1
72 months 144 000 km Maintenance #2
76 months 152 000 km Maintenance #1
80 months 160 000 km Maintenance #3
84 months 168 000 km Maintenance #1
88 months 176 000 km Maintenance #2
92 months 184 000 km Maintenance #1
96 months 192 000 km Maintenance #3
100 months 200 000 km Maintenance #1
104 months 208 000 km Maintenance #2
108 months 216 000 km Maintenance #1
112 months 224 000 km Maintenance #3
116 months 232 000 km Maintenance #1
120 months 240 000 km Maintenance #2
124 months 248 000 km Maintenance #1
128 months 256 000 km Maintenance #3
MAINTENANCE #1
MAINTENANCE #1 INCLUDES:
Replace engine oil and filter
Check fluid levels (pwr. strg., brake/clutch, coolant, washer)
Check tire condition and pressure (including spare)
Check exterior & interior lights for proper operation
Check windshield washer/wiper function
Check horn function
Check handbrake function/freeplay
Lubricate all latches, hinges and locks
* = if equipped
See "Model-Specific Maintenance"
MAINTENANCE #2
MAINTENANCE #2 INCLUDES:
Check horn function
Check engine coolant specific gravity
Check engine air filter; knock out dirt/bugs, replace as req'd
Remove wheels and brake drums, check pad/shoe thickness; inspect calipers, cylinders and shoes for proper function, leaks or damage; adjust rear brakes as required.
Rotate tires
Visually check underbody fasteners for condition & integrity
Check brake/clutch pedal freeplay
Check steering wheel components for proper operation
Check CV boots/tie rods/ball joint boots (visual inspection)
Check all seat belts and anchor integrity
Check exhaust sys. for leaks, mountings, brackets; heat shield
Check transfer case oil level & condition, fill as required
Check front & rear differential fluid, fill as required*
Check man. transaxle oil level & condition, fill as required*
Check auto transaxle fluid level & condition, fill as required*
Lubricate driveshaft u-joints (early Sportage only)
Road test vehicle
* = if equipped
MAINTENANCE #3
MAINTENANCE #3 INCLUDES:
Check horn function
Check coolant specific gravity
Inspect, deglaze, clean, adjust & lubricate brake components
Rotate tires
Check transfer case oil level & condition, fill as required*
Check idle speed
Inspect power steering lines & hoses (visual)
Check A/C compressor operation and performance*
Check brake line fittings, bleeder screws, booster for damage, looseness, leaks
Road test vehicle
* = if equipped
KIA MODEL-SPECIFIC MAINTENANCE
In addition to the KIA Basic Scheduled Maintenance, certain KIA Models will require the following maintenance services:
ALL MODELS
(Every 36,000 km or 18 months)
Manual transaxle service (except Sportage)
Automatic transaxle service (except Magentis)
Check drive belt condition & tension
Inspect front ball joints
ALL MODELS
(Every 48,000 km or 24 months)
Replace engine coolant
Replace engine air filter
Inspect fuel lines & connections
Inspect ignition wires
Replace spark plugs (except Platinum)
ALL MODELS
(Every 60,000 km or 30 months)
Replace brake/clutch fluid
Inspect EVAP canister & vapour lines
ALL MODELS
(Every 72,000 km or 36 months)
Replace fuel filter
Inspect PVC system/hoses for integrity
ALL MODELS
(Every 96,000 km or 48 months)
Replace spark plugs (Platinum)
ALL MODELS
(Every 102,000 km)
Replace timing belt
SPECTRA
(Every 12,000 km or 6 months)
Replace HVAC air quality filter (if equipped)
MAGENTIS
SPORTAGE
Transfer case, differential & manual transaxle service
Transfer case & differential service (auto. trans. model)
SORENTO
Jul 16, 2014 | Kia Sportage Cars & Trucks
I slambed the lid shut, and somehow disabled the hard disk, can I plug it back in?
You think your hard disk is unplugged due to slamming a lid closed? If thats the case then the answer is yes. Get a screw driver and un screw both screws on the bottom of the laptop with the power cable unplugged and the battery out of the unit. Press and hold the power button down for sixty seconds before reseating the hard drive or connecting any cables to it.
it is very unlikely and kind of unusual that the hard drive would just become unplugged due to slamming a lid down. I hope you have not damaged the drive instead? If thats the case then there is nothing you can do but purchase another one.
Aug 16, 2011 | Acer Aspire 4720 Notebook
Seagate 500GB FREEAGENT DESKTOP 7200RPM EXTERNAL USB 20 HARD DRIVE 16MB it just stoped working in the middle of the movie, complete blackout, tryed conect to another PC nothing came up, what it could be...
Try this:
1. Turn off the power supply to the hard drive.
2. Turn off your PC/laptop.
3. Connect the hard drive to the PC/laptop.
4. Turn on both devices.
It worked with mine.
You could also try installing Seagate Manager which can check for errors on the drive.
Jun 10, 2011 | Seagate 500GB FREEAGENT DESKTOP 7200RPM...
I have sony digital8 dcr trv 285e handycam but its picture package is not compatible for window 7 i want to watch my cassettes on my pc and convert them in to dvd also what is the solution
You will need a firewire cable tro connect to the PC and use Windows Movie Maker to capture the tapes to a hard drive, dedicated hard drive is best. Expoect about 13 gig of drive space per hour.
You then export you footage to a DVD Authoring program if you have one available.
Mar 05, 2011 | Sony DCR-TRV285E Digital-8 Digital...
My wife drop the laptop on the floor and since then when i start the laptop it says no boot device found.
Two possibilities here:
1. When your laptop was dropped, the connecting between the hard drive & the laptop's motherboard became loose, & as a result the motherboard could not properly detect the hard drive. Solution here is simple: Try removing the hard drive & replacing it back in the laptop & see if this resolves the problem.
2. If the case did not turn out to be as described in point (1), then most probably your hard drive is damaged as a result of the fall. In this case you will also need to remove it off the laptop, but you will have to buy & install a replacement hard drive, & re-install the operating system & all other software.
The document at the following link describes how to uninstall/install a hard drive in your laptop's model:
http://support.dell.com/support/edocs/systems/latd600/en/sm/hdd.htm#1123687
Aug 25, 2010 | Dell Latitude D600 Notebook
I have a video of a sailing ship entering harbour. The sound is not very good and I would like to change this to a suitable musical track.
If you have a PC with windows movie maker installed export your footage via USB2 into your video folder on PC then drag & drop or import your video into movie maker.Rip a CD music track in media player & drag & drop or import into movie maker.
turn down volume of original sound & replace with new soundtrack then publish the movie in format of your choice.
If you get stuck read movie makers help folder.
Aug 13, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
I accidentally deleted a movie off my camcorder. Any chance of getting it back? I have the Sony DCR-SR60
Hi, there. Don't worry. I recommend you to use this camcorder recovery software named asoftech data recovery
http://www.asoftech.com/adr/
It can help you recover your lost photos and video files from your camcorder (or Memory Card).
Jul 28, 2010 | Sony DCR-SR65 Flash Media Camcorder
I CONNECT EXTERNAL HARD DRIVE TO PC WITH XP AND IT DID NOT RECOGNISE EXT HARD DRIVE HELP PLEASE
dear sir
good day
try to replace the USB cable and test the Hdd on an other computer system to make sure it is function and good luck
Dec 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
How to convert dv tape from Canon ZR20 to MY COMPUTER hard drive?
To transfer video off your minidv cassettes from your camcorder you would need to have a firewire connection to your PC. Either a 4 to 4 pin connection (laptop) or a 4 to 6 pin (desk top computer). USB is used only for picture still transfer. Here are the steps;
1. Plug your mini Dv camcorder into an outlet
2. Plug in you firewire connection into your computer, then plug the other end into your camcorder.
3. Turn on your camcorder and switch your camcorder to Play/VCR
4. Select the software that you want use to do the transfer. Windows Movie Maker is the most assessable software since you have XP on your computer
5. Name your file
6. Select capture from video device (automatically will allow you to save the entire tape and manually would allow you to capture parts of the tape).
Those are the basic steps in some detail. You can save your file from there or you can go on to edit.
Jan 02, 2009 | Canon ZR20 Mini DV Digital Camcorder
E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop Logo
105 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
