Question about Craftsman 8 amp Reciprocating Saw with Soft Carry Bag 3 pc Blade Assortment
How do I remove the nose piece to repair the reciprocating shaft.
The reciprocating shaft on my 6 amp model 900.271221 saw does not move even though the armature still spins.The saw is way beyond the warranty and I wanted to get an idea of the damage so I could order parts.
  • 43,501 Answers
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
Posted on Aug 27, 2010
A piece of a broken blade is stuck here the blade fits into the saw (Dewalt DW 303m). How do I get it out?
Craig, a drop of penetrate oil and you will just have to work at it with ice pick.small screwdriver, or needle nose pliers if you can, make sure you have blade release depressed while trying to pry blade shank out. Once you get it moving it will fall out. Clean and blow out blade port before inserting another blade.
How to Remove Stuck Blade on Sawzall Hatchet eHow
Troubleshooting Your Malfunctioning Reciprocating Saw DoItYourself com
May 26, 2016 | Dewalt Saws
Blade doesn't move (reciprocate)
The drive shaft for the blade is stripped or broken. take it back where you bought it.
Oct 31, 2012 | Dewalt DW303 Heavy Duty 65 Amp...
I need directions on how to change the baldes on a reciprocating saw.
There are 2 types of clamps that hold the blade in that type of saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
How can I remove the blade. There is an allen screw that I removed but the blade is still attached to something.
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 26, 2010 | Craftsman 8.0 amp Reciprocating Saw
I have a sears reciprocating saw with a broken blade.I can't remove the busted blade.Is there any way of removing it?
heatman101
Aug 19, 2010 | Craftsman Saws
Pin and lock where the blade is come off and giving me a hard time putting it back
heatman101
Aug 15, 2010 | Skil 9.5 Amp Orbital Reciprocating Saw...
How do i change the blade in a reciprocating saw?
heatman101
Aug 05, 2010 | Skil FactoryReconditioned 920501RT 85 amp...
Shaft or rod seems to be broken
The gears are stripped internally in the saw...it will need to be repaired..usually there are regional service centers for repair...look for the one closest to you...
heatman101
Jul 26, 2010 | Craftsman 85 reciprocating saw 926770
Can not replace blade on Dewalt 303 6.5amp
heatman101
May 23, 2010 | Dewalt DW303 Heavy Duty 65 Amp...
Reciprocating saw-snapped blade-cannot be removed
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
May 26, 2009 | Craftsman 8.0 amp Reciprocating Saw
Craftsman 8 amp Reciprocating Saw with Soft Carry Bag  3 pc Blade Assortment Logo
428 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
