Question about Dewalt 12" Beveling Sliding Compound Miter Saw Dw718
How to grease main blade bearing on dw708 12' mider
I cant find a grease point
Cub cadet riding mower Mower Blade and shaft wiggle
I am not familiar with Cub Cadet but would suggest that if spindle is loose [wiggles] then one or more bearings need replacing. Remove the whole deck from the machine and turn over. Check the blade [s] are firm. If not undo the nut holding the blade on and remove the spindle and its housing from the deck frame. Remove the driving pulley also. Usually these types of drives have a spindle with a special fitting on the lower end for the blades to fit onto. Some are forged on the end of the spindle and the bearings come off the other end. Others will be removeable and so the bearings will come off each end. What ever, clean up with fuel and replace both bearings. You may have to remove the seals on the inside to let grease in. Make sure the top bearing has plenty of grease as it may miss out if all the grease goes down. Some machines it is better to leave the seals on top bearing. I have found that it does not pay to use the hose connection to clean the deck as the water destroys the bearings and only half cleans the deck. Best to put planks onto trailer or ute deck and run mower up so you can get underneath with big screw driver every now and then. Take blades off and sharpen them then also.
Aug 21, 2014 | Garden
1991geo prism lubrication points
old post, and one of them hard , asking for whole book.
PRIZM , 2nd year, its toyota corolla for sure.
lost the operators guide? chapter 7 covers all that.
buy one ?
as in grease? (points?) or all dino oil lub points.
you need a count, sorry I never do counts..
lubrication is and huge wild field (as in)
we even oil hinges... on all cars.... so.>> why not just read the book yourself, I cant paste in chapter 7 here, sorry.
engine oil is not grease, nor axle lube or transmission
why not ask by category.
suspension (none)
or drive line. sure...
engine and trans yes, and axles yes
the operators guide tells all this.
axle bearings , sure, some bearing can be greased,
some cant, depends on what's there. (sealed bearings happen)
hinges, sure. ,cables yes,
transaxle fluid (lube) sure.
why not ask this in a more clear and simple way
what lubrication points are unique to this car,
answer, none.
read any service guide on any car, and bingo, same.
same for same. FWD car for FWD car.
same... 40million strong. now.
page 7-7 has many lub points, shift linkages
park cable guides
underbody contact points it says.
there are 40million corollas made
all have owners manuasl, Id bet most all of them read the same.
i have 95 manual. here, and see NOTHING unique.
SOP standard operating procedures and service.
Feb 23, 2014 | 1991 Geo Prizm
Can you repack the blade bearing on Vitamix Blenders?
On the Vitamix blender models we have here in NZ it is not possible to repack the bearings, you just purchase a new blade assembly complete with bearings and the driving clutch.
Nov 11, 2013 | Vitamix Super 5000 Work Top Blender
Proform ZE3 Elyptical screeches constantly
FOLLOW THIS STEPS AND FIX IT. God bless you Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Link Arms
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
Hold each bearing next to one ear and turn the inner race with your finger. If you hear grinding noises or the bearing is rough, it must be replaced. Lubricate the bearing with lithium grease and a grease gun. Replace the bearing into the hub. Reattach the lower handlebars and footpad link arms and put the elbow covers on.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Mar 22, 2013 | Exercise & Fitness
Pedal tention too tight
Step 1:
please proceed with this step . Happy new year and God bless you
Lubrication
Step 2:
Pedal Arms
Step 3:
Link Arms
Jan 01, 2013 | Exercise & Fitness
My proform spacesaver 500 eliptical is making a clicking sound
follow this steps and fix it. God bless you
Lubrication
Link Arms
Pedal Arms
Nov 30, 2012 | Exercise & Fitness
Pedals are locked won't spin foward but will spin backward
see the following steps, and fix it. God bless you
Pedal Arms
Nov 28, 2012 | Nautilus R514 Recumbent Bike
Noise from bearings
see this steps and fix it. God bless you
Pedal Arms 1
Link Arms 1
Lubrication 1
Oct 15, 2012 | Proform Pro Form Sears Elliptical Drive...
How do you service, ie grease the shafts that hold the mowing blades, I see no grease fittings. It is a 638 RL Yard Machine
Hi, they run sealed bearings with no grease nipples. I replaced my bearings when they became noisy and drilled and tapped the housing and fitted grease nipples to extend the service life of the bearings. Hope this helps, regards Phil.
Jul 19, 2011 | Garden
I have a Gelatao Magnum Plus that makes a horrible sqeaking noise
Maybe blade assembly it's loose, or bearing are dry, if you can take apart, use grease on the shaft and bearings. or replace motor.
Dec 23, 2009 | Kitchen Appliances - Others
Dewalt 12" Beveling Sliding Compound Miter Saw Dw718 Logo
166 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
