Question about Samsung ML 1430 Laser Printer
We have a thin down the middle of the page
We have a thin black steak down the middle of the page
  • 1,110 Answers
2 words. Toner Cartridge.
90% of all print quality issues on laser based printers such as this are caused by a defect in the toner cartridge. Swap the cartridge and fix this problem. If you dont have a spare try removing the toner cartridge and looking at the drum cylinder in the cartridge. If you see any kind of similar black line on the drum you will have proof that it is the cartridge. The ONLY other possible cause would be the fuser unit. But my money is on the toner cartridge.
Good Luck and Thank You for using Fixya.
Posted on May 12, 2010
Recipy for Steak Pecado
Give this site a try. This lady is really into her food. Lots of 'talk' but the recipe is further down the page.
Steak Picado and Guide to Peppers The Complete Savorist
Sep 16, 2017 | Grilling
What size is 3 ounces of thin cut ribeye steak
the size is 3 ounces. size depends on thickness shape density. that's why they measure by ounces its the only way to measure the size. its like 4 or 5 mouth fulls. very small portion. most steaks are at least 8 ounces
Mar 16, 2013 | Cars & Trucks
EPSON WORKFORCE 840 AUTO FEED COPIES HAVE BLACK LINE DOWN THE SIDE
This was my exact problem. When scanning from the ADF, I had a vertical black line down every page. I cleaned the larger glass surface several times with no effect. Then, I discovered that ADF scans do NOT use the large glass area, but use the smaller, thinner glass area on the left side. It has a piece of thin plastic over the top of the glass. The scanner is fixed and the paper rolls through this area. So, if a speck of dirt is under the thin plastic piece or on top of the glass or on top of the thin plastic, it results in a black line down the whole page. Aha, so now I cleaned the thin plastic (both sides) and the top of the glass under the thin plastic - actually saw the black dot that was causing the problem and voila, problem solved.
Jan 30, 2012 | Epson Office Equipment & Supplies
There is a black line going down the middle of the page when I photocopy something
Because you haven't mentioned what kind of printer you have, I'll have to guess at giving an answer. I have to assume that you are using the automatic document feeder(ADF). Lift the scanner lid. To the left of the big glass rectangle there should be a thin glass strip. That is your problem. Clean it good. Glass cleaner works fine.
Sep 22, 2010 | Office Equipment & Supplies
A black line is printed down the middle of pafe
The problem may be from either from the toner cartridge or the settings of the printer. change the toner first and see whether he problem still persist and also make sure that the settings of the printer on your system is ok, if the problem still persist after doing all this then it implies that you need to service your printer.
Sep 25, 2009 | HP Office Equipment & Supplies
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Blurred prints
It really sounds like you need to replace the imaging unit.
May 15, 2008 | Xerox Phaser 6115MFP/N Laser Printer
Line down middle of copy Officejet 6110
have you check with new cartridge. if the problem is still there with new cartridge then your printer needs cleaning from inside.give it to service.
Apr 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Samsung ML 1430 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
