Question about Consew 226R-1
Where is the bobbin reset button? I'm working on
Where is the bobbin reset button? I'm working on a used machine, and the bobbin holder is JAMMED and the machine owner says there's a reset button. Thanks for the help.
  • 36 Answers
The reset button should be a silver button smaller than a dime on the bed of the machine. if you were looking at the machine as you would while sewing the button would be half way between the needle and the innermost part of the throat. Push and hold the button then turn the main pully backwards it should stop and the turn it forwards and the ball bearing should drop in place. you may have to let go of the button on that one when you start turning it forward.
Posted on May 23, 2010
A thread is caught in the bobbin apparatus. Took bobbin case out and machine is still jammed. Can I take it apart and get the threads out? What to do...
Only thing is to remove the bobbin, bobbin holder if you can, the feed dog cover plate, and then, using a magnifying lamp and a fine pointed pair of tweezers, try and locate the bits of cotton and pull gently out while rotating the hand wheel slowly, rocking it back and forth. Use an air blaster can to blow fluff out, clean, and oil. Including inside the bobbin case.
Feb 26, 2017 | PfaFF Sewing Machines
How do I get my machine to start sewing and stop beeping?
try rethreading the machine--use EVERY thread guide
make sure the needle is inserted up into the needle holder and turned the right direction
make sure the bobbin is inserted correctly into the bobbin case and turned the right direction
clean under the needle plate and in the bobbin area for loose thread or lint
make sure thread has not come off the thread take up lever
also the jam could have caused the machine to jump time and needs a timing or a adjustment
Jun 06, 2015 | Singer 7436 - INGENUITY
Remove thread jammed in bobbin case holder
Just open carefully the front of the machine (attention where everything has to be put back), identify the problem and try to remove the thread. Inspect the inside of the machine and the lower bobbin case for thread that may be tangled . Take it easy and you will fix it ; most of the times you we'll not need professional help. Post back to tell us where the problem was and how you fixed it.
Sep 29, 2014 | PfaFF Creative 7570
Juki ddl 8300n
The part that holds the bobbin case down must have enough room for thread to move across the top of the bobbin case without getting jammed. Turn the hand wheel while you monitor the movement of the thread. If it gets jammed you will have to adjust the holder by loosening the bottom screw and move just a small amount. Also check your bobbin to make sure it is the right size. If it is too high it will jam the thread.
Mar 24, 2017 | Sewing Machines
Using a Pfaff Hobbymatic 935. Needle will not move, mechanism around bobbin will not move. Everything is locked in place. Tried cleaning everything, removed the needle (to get the fabric out of the way),...
It is likely the the bobbin holder is jammed up with cloth or thread. Take the bobbin holder out and turn the machine by hand, if it does not move it could have a broken timing belt or slipping coupling.
Apr 13, 2011 | PfaFF Sewing Machines
I tried to change the bobbin and the machine would not run, so I took it out and now I can't get bobbin out of the holder. It appears to be stuck.
The lever on the front of the bobbin holder locks the bobbin so it does not fall out when you insert the assembly. Do not lift the lever when you try get the bobbin out, it should just fall into your hand. If it does not, look to see if the latch on the lever has not jammed on the bobbin.
Feb 15, 2011 | White Sewing Sewing Machines
I threaded it all right i have cheacked it many times but the thread in the bobbin keeps getting jammed
Many causes for this problem. Most common are;
  1. Top thread not inserted correctly.(must keep thread tight.)
  2. Debris and loose thread around the bobbin cage. All it takes is a tiny piece of thread in the right place.
  3. Bobbin inserted backwards in the "bobbin holder". When installed correctly, There is some resistance when you pull on the thread, but the bobbin will spin without trying to pop out of the "bobbin holder".
Oct 29, 2010 | Brother XL-5500 Mechanical Sewing Machine
My bottom thread keeps getting jammed when I start sewing. What's goin on?
It sounds like the bobbin may be positioned wrong (it should turn counterclockwise when you place it in the holder) or the bobbin is not pulled completely through the notch in the holder.
Also, make sure your top thread is threaded properly too. Sometimes I've had problems when I thought it was the bobbin but it turned out to be my main thread.
Hope that helps.
Oct 15, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Machine not working
I had this happen the first day I got my machine. The bobbin case has probably came loose from the holder. There is a step by step cleaning instruction in the manual and it tells you how to reset the bobbin case in the holder in the manual.
Nov 15, 2008 | Husqvarna Viking 1
Bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Aug 07, 2008 | Sewing Machines
Consew 226R-1 Logo
226 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
