Question about Water Pik & Wallmount Showerhead
Water leaks shere showerhead joins the shower stem
We have a 2-jointed rain showerhead.
Took it off the shower stem for cleaning and in re-assembling the leak comes where the shower stem from the wall joins the Water-pik shower head. One joint is at this joining; the other joint allows the actual round head to be set in different positions. I't the top joining that leaks. Help!
  • Randy Marshall May 13, 2010
    Did it have a washer in it and did you use telfon tape on threads.
  • dyoung6 May 14, 2010
    Yes, to both questions. Is there something more we can do to bring about a "no leak" fixture?
  • 33 Answers
When reconnecting the shower head to the pipe coming from the wall..
did you use some pipe tape, pro dope or another type of joining compound?
this seems likely to be the problem.. if you don't have any on hand, visit a hardware store and ask their staff for pipe tape for plumbing and you should be pointed into the right direction.
Posted on Aug 03, 2010
How do i install showerhead
REmove old showerhead using two wrenches, one to hold the stem from the wall steady, then twist the head counterclockwise. Use the same wrenches to install the new one, twisting the head clockwise to tighten. But before you put it on, clean the threads on the stem with a rag and wrap teflon plumber's tape around the threads clockwise 4-5 turns. That keeps it from leaking and makes it easy to remove in the future.
May 26, 2014 | Hansgrohe Shower 27495 Raindance S 150 Air...
How do you replace the cartridge in a Ondine volume control valve for a shower
Turn off the water supply before you work on the control valve.
You need to remove the lever/handle first and covers so that you can see the stem of the control valve. Then, use a spanner to unscrew the stem/cartridge.
Feb 22, 2014 | Ondine Brass Showerhead
I have an American Standard Colony? bathtub faucet set that has been leaking at the spout. I thought the reason for the leak was the seats and rubber washers needed to be replaced. After doing so I still...
Check these items:
1. If you installed new faucet seats, did you add a little pipe joint compound to the threads before installing them?
2. Make sure the shower diverter is in the off position and you're not seeing water leaking from the spout that could be coming from the shower pipe or residual water from the shower head.
3. Make sure you have the correct faucet washers - some or tapered and some are flat and must fit the stem counter bore correctly and that the counter bore isn't damaged or the stem shaft isn't bent. Make sure the waskers are the correct hardness.
4. Make sure the screws that secure the faucet washers are tight, but not too tight. It doesn't hurt to add a little pipe joint compound to the screws.
Aug 28, 2010 | American Standard Colony 3275.505 099...
I have the Eco Rain showerhead and about half the nozzles are no longer putting out water. How can I clean them out?
Disassemble and soak it in a lime cleaning solution or vinegar. I have include a link below with more information for you. I hope this will solve your problem.
http://www.wikihow.com/Clean-a-Heavily-Clogged-Up-Shower-Head
Jun 16, 2010 | Water Pik WaterPik& Ecoflow Hand Held...
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Shower diverter problem
It is very possible that a piece of rubber from the old washer or some debris has found its way into the shower diverter or the showerhead. The first thing to try, is to take off the showerhead and see if you get water without it. If you get water then your problem is solved!!! Puchase a new showerhead or take apart the old one and soak it in CLR or Lime-Away to clean it. If that doesn't do the trick than, Turn off your water supply to hot and cold. Remove the diverter (if possible) and inspect for debris. If you want you can also take out the hot and cold stems for a total inspection of the inside of the faucet. You can then flush out the inside of the faucet cavity with a Turkey Baster or something to that effect. Put it all back together ( use a bit of vasaline on all the rubber washers so they do not get stressed when re-installing) and you should be able to take a shower.....Also, if it was a cartridge you replaced, you may have inserted it 180 degrees opposite......Hope this helps.....Joe
Jan 12, 2009 | Ace Hardware BRASSCRAFT 45458 "ACE"...
Getting handheld showerhead plus rainhead - which valve? - a pressure reliefvalve or thermostatic valve
I installed a 2 thermostatic valves in our shower. Two of us can use both showerheads simultaneously without being frozen or scalded.
Kind Regards,
IT_handyman
Oct 25, 2008 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
Water Pik & Wallmount Showerhead  Logo
151 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
