How do I lock the "Clips" back after opening up a kenmore washer "Top/front"
  • 5,911 Answers
If you are referring to a Kenmore TOP LOADER and you are trying to reinsert the brass-colored j-hooks that hold the washer case to the back panel, follow these steps:
1. With the lid of the washer casing open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame base in the front.
2. Lower the washer casing back onto the side frames. Make sure the small cleats on the side frames fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
3. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you to seat it.
4. Reinsert the brass clips. Place the 90 degree bend of the clip into the slot on the back of the washer first, and then forcefully push the J-hook end of the clip down into the opening on top of the washer. NOTE: Once the clips are snapped back into place, the washer case should fit tight and not move on the frame.
5. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
6. Reinstall console.
If you are not referring to a Kenmore top loader, configured in this manner, please post back with your MODEL NUMBER so I can determine how your washer is configured. These instructions apply to the majority of all Kenmore top loaders. I hope this helps you.
Posted on May 12, 2010
  • tigtig33 May 14, 2010
    No luck trying to force clips into lid, Im a mechanic by trade cant figure it out.
How do i open the top of my kenmore washer to replace a part?
There is two spring like clips in the front of the washer. Use a thin scraper. You have to start prising up on the top and push the clips back with the scraper and it will pop open. they are about two inches from each side, approximatlly.
Dec 03, 2011 | Kenmore 24032\24036 Top Load Washer
How do I get the top up on a kenmore washer. I need to replace the lid micro switch.
Their are 2 different ways to remove the top based on when that washer was made the manufacture used differnt methods this is how to do it on each style
remove diagonal panel between washer and control panel
in the back of washer top will either be 2 brass colored clips
or in the very back egde of top will be 2 5/16th inch hexhead screws
for clips place a small screwdriver in front of that clip and pop clips off and slide top forward
for the screws remove screws from behind top in the left/right corner..pull top forward a bit and lift up a little the plug for the lid switch will be in front right side..squeeze the release for that plug,unplug swicth plug then remove top
in both cases lid switch asm. will be on right side of top on the underpart of it
Gene
Aug 24, 2011 | Kenmore 80754 Top Load Stacked Washer /...
The switch # 3949238 on my kenmore washer #110.29842991 is broken. how do I remove the top cabinet so I can replace the part?b
Disconnect the power first.
Many washers have spring clips holding the lid in place, and a putty knife or scraper can be shimmied in to compress the clips and open the lid for service.
Some units, esp old Maytags, have 2 screws near the bottom of the front panel, and removing them will let the front panel tilt out, granting access to the top cover from the front.
Some later Whirlpool and Kenmore units have a cabinet that comes off in one piece. You'll need to remove 2 screws holding the splash panel to the top of the washer. Flip the panel up giving access to the timer/switches area. Disconnect the white plastic wire connector, then use a screwdriver to pop the metal clips in the corner. Set these aside, and the whole cabinet will tilt forward, and can then be lifted off the washer base/back. Space to work will be an advantage, for this type of cabinet.
May 18, 2011 | Kenmore Washing Machines
I just replaced the door latch on my kenmore front loader washer model 11047532601 the door locked light doesnt come on and the door locked light isnt coming on all i get is beep beep beep
You have a bad CCU. This is the control board on the top of the unit. Remove the top, three screws on the back. The board clips into the position. You can try to unplug the wires one at a time, the control will probably have to be replaced.
With the model I would be able to better assist you.
Mar 31, 2011 | Kenmore HE2 Plus Front Load Washer
How do i open washer of stack dryer washer to get to motor area. is front panel snaped on?
remove the angled panel between the washer and dryer, you will see either 3 or 4 screws holding the top of the washer in place or 2 gold colored clips. remove the screws(or clips) and the top should slide forward and come off. this gives you access to the screws holding the front in place.
May 05, 2010 | Kenmore 98702 Stacked Washer/Dryer
How to remove top of kenmore oasis washer to replace lid lock mechanism
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Model #110.26901691 Kenmore washer. Need to
The end caps come off by placing your hand over the TOP of the console and lifting each one from the back and pulling forward. If you can't get them to come off by hand, try placing a screwdriver in the top groove in the back and give it a twist to pope the cap free. Once the caps are removed follow these steps:
1. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
2. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
3. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
4. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If you are replacing the lid switch, you will now have full access to remove it from the under the washer casing.
To reinstall the washer case, follow these steps:
1. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions about this repair, please post back and let me know. You can view some excellent exploded view diagrams of your washer at searspartsdirect.com for assistance in locating parts if needed. I hope this helps you.
Dec 08, 2009 | Microwave Ovens
Getting off the End Caps
The end caps do not come off on this type of control panel. There is a retaining clip holding it in place at each front corner. You need to insert a putty knife between the top panel and control panel at the left and right front corners. Push the knife straight in from the front and push to release the retaining clips while lifting the panel. Once both clips ar released, the panel will open up. You can view a diagram of the console at searspartdirect.com. Just type in your model number and look under the "Control Panel Parts" heading. The retaining clips are listed as item number 8.
NOTE: Sometimes the clips will come off and fall down inside the washer cabinet. If this happens, you may be able to retrieve the clip by moving the washer and looking underneath. However, if it becomes caught somewhere inside the cabinet, you will need to remove the exterior cabinet to retrieve it. Just follow these steps:
1. Unplug washing machine.
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
4. Reinstall console by aligning the retaining clips with the holes on the top panel and pushing straight down until you hear a "click".
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Sep 18, 2009 | Washing Machines
Lid switch is broken How do I remove top to replace?
If your washer is a top loader, look at the front edge of the washer just about 2-3 inches in from each side, there should be small indents just at the bottom of the top lid frame. You need a 1 inch wide metal putty knive to push it at each of these indents, one at a time to release the locking springs.
Once you've done this, the washer top frame will be able to be lifted up to gain access to the inside of the washer and the underside of the top frame. You should then be able to remove and replace the faulty switch.
Sometimes there are additional locking screws on the back side of the top panel that secures the panel to the main cabinet. Just be sure to check for these if after disengaging the front locking spring clips, you can't lift the panel up very far. Don't try to force it up, it should move freely if there are no other locking clips or retaining screws holding it in place.
Be sure to unplug the washer before performing any service work.
Hope you found this very helpful and best regards!
Aug 06, 2009 | Kenmore Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
