Question about Viking Professional (2-Slot) 2-Slice Toaster
When sliding the toaster arm down, it will not stay down.
When putting the bread in to toast, the toaster bar will not stay down and so it will not trigger the toaster to start. So no toast. Simple problem, hope the solution is as simple.
Hi my girlfriend just gave me this toaster, and would like to know what the lighted buttons are for thanks
Since you don't mention the make or model number of the toaster or its age I can only make the following guesses.
It might be an electronic model. To test if this is the case, leave the toaster unplugged and push the lever of the toaster down. If it does not stay down it is an electronic toaster. If it stays down then it is NOT electronic.
The lights might be lighted push buttons.
If you plug the toaster in then put a slice of bread or two in and push the lever handle down and one light comes on then this is probably a dual purpose pushbutton. It indicates that the heating elements are on and if you push it will cancel the toasting cycle and the bread slices should pop up.
If there is a button beside the above button it could be for extending the toaster cycle time a bit longer to compensate for a thicker slice or a denser bread like a bagel. If you push it, it will light up to let you know that the cycle has been extended for this reason.
If there is a button beside this one, it could be for extending the toasting cycle to compensate for a frozen slice of bread or whatever, like a bagel or even a frozen waffle.
If you find the make and model for your toaster, it might be on the bottom somewhere, google it to see if you can download an instruction manual for it.
Hope this helps. Good Luck.
Jun 03, 2017 | The Kitchen Appliances - Others
Control lever will not stay down
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
Apr 08, 2014 | Bodum 10709 Toaster
I HAVE A RADIANT TOASTER THAT WHEN IT LETS THE BREAD DOWN IT DOESNT WANT TO CLICK OFF & LET THE TOAST UP & KEEPS LETTING IT DOWN ABOUT HALF WAY UPHVAUGHN30
Try cleaning the bread crumbs out of the thermostatic release mechanism. If necessary, lubricate the slides with a light, high temperature grease, but apply it very sparingly.
Jan 16, 2011 | Kitchen Appliances - Others
We have the four slice toaster. The arm on the left will no longer stay down. The side still toasts, but the arm will not lock in the down position.
try removing the lower claening plate and remove the bread crumbs and see if that makes it work again. Many people don't know there is a cleaning try on the toaster.
Mar 21, 2010 | VillaWare 5850 Uno Classic 4-Slice Toaster
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Viking Professional (2-Slot) 2-Slice Toaster Logo
70 people viewed this question
Top Viking Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Kitchen Appliances - Other Expert? Answer questions, earn points and help others
